keil5 compile success but load fail
Error information and related set up are as follow:
command not supported
I need your help, thank you!!!!QWQ
Use an Authentic ST-LINK with current firmware on it supporting the L4 parts.
Sorry, may I ask more details?ಥ_ಥ
Do you mean is STLINK the problem? But I use the STLINK that comes with the development board and I can see it in Device Management on the computer. So could you please tell me more about it?
Sorry I have just started with this field.QWQ
Thank you very much!!!!!!
And I've upgraded the STLINK to the latest version. May I ask you what version it should be? Thank you!!!
It doesn’t work.ಥ_ಥ
You had J17, seem to recall J34 being current.
The serial number looks invalid, suggesting you have a clone/boot-leg device.
What does the pop-up error actually say? Does the ST-LINK Utility work externally from Keil?
Custom board? Has it's functionality actually been established?
The L4 also sometimes has dual/single bank flash configurations, requiring the appropriate flash algorithm to be selected.
solved!!! Thank you very much!!!
