Dear Sirs,
I want to write a function likes below,
int sub(unsigned int x)
#pragma ASM
MOV A,#x
#pragma ENDASM
But the keil-C shows the message: error A45: UNDEFINED SYMBOL (PASS-2)
Does the Assembler not know how to access the variable in C ?
How could I pass the variable from C to assemble?
Really thanks for your reply.
BR,
Eddie
Some related Keil- and Arm-docu to refer to:
- "C51: MIXING C AND ASSEMBLY" : http://www.keil.com/support/docs/1671.htm
- Embedded assembler syntax in C and C++" : http://www.keil.com/support/man/docs/armcc/armcc_chr1359124253861.htm
- "Inline assembly language syntax with the __asm keyword in C and C++": http://www.keil.com/support/man/docs/armcc/armcc_chr1359124246903.htm
- "Writing inline assembly code": http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.100748_0606_00_en/lmi1470147220260.html
shihwen chou said: I want to write a function likes below
Why?
If it really needs to be done in assembler, then do it in a proper assembler module.
For an easy way to create a 'C'-callable assembler function, see:
http://www.8052mcu.com/forum/read/149030
I wholeheartedly support using that approach, inline assembler usually end up in something unmaintainable.
in my book "difficult to maintain" equals unmaintainable
