I am using KEIL µVision 4.74.0.0 with ARM compiler 5.03.0.76 on Windows 10.
When I put my web src files into fcarm.exe, I get absolutely no output, and also no error message. The tool calculates quite some time (maybe 10 s or so), and then outputs just nothing, neither when listing my input files directly, not using a command file.
Example:
C:\Keil\ARM\BIN\FCARM.exe @Web.inp
Where Web.inp is:
bootstrap-theme.min.css,~bootstrap.min.js,bootstrap-theme.min.css,index.cgi,io.cgi,~jquery.min.js,Logo.png,style.cssto Web.c nopr
When I leave out "nopr", then an empty "Web.lst" file is created, that's all.
Can anyone give a hint how I can check what is going wrong?
Hello hgl,
have you tried to change the "to" to 'TO"? Oh and why do you have the bootstrap-theme.min.css twice in your command file?
Kind regards,
Christopher
Hi Christopher,
thanks for your answer!
- both "to" and "TO" behave the same way
- sorry, bootstrap-theme.min.css was a copy/paste problem
I have experimented a bit and found out that my source file "index.cgi" causes the problem. When reducing the whole thing to
fcarm index.cgi to web.c nopr
then I already get no output. I have broken down the content of index.cgi to "<html><body>This is a test.</body></html>". Observation: when renaming the file to "index.html" it works. As "index.cgi" there is no output.
It seems that I need to investigate further how my predecessor developer converted this - maybe he did some preprocessing on the cgi files before using fcarm. Thank you for the support anyway, and sorry that I'm coming up with such weird stuff - I didn't start this project, just trying to continue someone else's work...
Regards, hgl
no worries! I'm happy that you're on the right track now.
Hi hgl,
The version of FCARM.exe you are using is probably v2.50 (shipped with MDK4.74) This version had a problem with the cgi conversion, which was fixed in a later version. If the following conditions were met, FCARM.exe crashed and gave no output:
- cgi file contains exactly one line (no return character on first line) - line uses i,t, or c command - cgi does not end with the "." command character
Try to avoid this as this may solve your problem.
Regards,
Franc
