Keil Flash Error
Hello, i am having trouble in flashing a simple program in to a 8051 device with a usb kit. The device i am using is a  "at89c51ic2"
when i build target does not show any error or warning, but when i try to flash, this error shows up:
  • batchisp -autoisp -device AT89C51RD2 -hardware RS232 -port COM5 -baudrate 9600 -operation MEMORY FLASH LOADBUFFER "C:\Keil_v5\C51\Examples\Objects\teste.HEX" PROGRAM START RESET 00
  • --- Error: failed to execute 'batchisp -autoisp -device AT89C51RD2 -hardware RS232 -port COM5 -baudrate 9600 -operation MEMORY FLASH LOADBUFFER "C:\Keil_v5\C51\Examples\Objects\teste.HEX" PROGRAM START RESET 00'
with this i went to the "options for target" ->"utilities" to make sure but i did not found nothing :(
this is what is the box:
"-autoisp -device $D -hardware RS232 -port COM5 -baudrate 9600 -operation MEMORY FLASH LOADBUFFER "#H" PROGRAM START RESET 00"
if anyone could help finding the problem it would be great, i am losing my mind :'(
sorry for my bad english
0
