I opened C:\Keil\ARM\GNU\Examples\Blinky project and opened Project->manage->components..books dialog to set the GNUARM tools:select USE GNU compiler
GNU-tool-prefix:arm-none-eabi- cynus Folder: C:\Program Files\CodeSourcery\Sourcery G++ Lite
then Build target :
then a lot of error MSGs:
Build target 'MCB2100 Flash' assembling Startup.s... Assembler messages: Error: Error: can't open .FlashStartup.o for reading: No such file or directory compiling Serial.c... Serial.c(10): error: LPC21xx.h: No such file or directory Serial.c: In function 'init_serial': Serial.c(16): error: 'PINSEL0' undeclared (first use in this function) Serial.c(16): error: (Each undeclared identifier is reported only once Serial.c(16): error: for each function it appears in.) Serial.c(17): error: 'U1LCR' undeclared (first use in this function) Serial.c(18): error: 'U1DLL' undeclared (first use in this function) Serial.c: In function 'putchar': Serial.c(26): error: 'U1LSR' undeclared (first use in this function) Serial.c(27): error: 'U1THR' undeclared (first use in this function) Serial.c: In function 'getchar': Serial.c(36): error: 'U1LSR' undeclared (first use in this function) Serial.c(38): error: 'U1RBR' undeclared (first use in this function) arm-none-eabi-gcc: .Flashserial.o: No such file or directory compiling Blinky.c... Blinky.c(10): error: LPC21xx.h: No such file or directory Blinky.c: In function 'delay': Blinky.c(33): error: 'ADCR' undeclared (first use in this function) Blinky.c(33): error: (Each undeclared identifier is reported only once Blinky.c(33): error: for each function it appears in.) Blinky.c(35): error: 'ADDR' undeclared (first use in this function) Blinky.c: In function 'main': Blinky.c(53): error: 'IODIR1' undeclared (first use in this function) Blinky.c(54): error: 'ADCR' undeclared (first use in this function) Blinky.c(60): error: 'IOSET1' undeclared (first use in this function) Blinky.c(62): error: 'IOCLR1' undeclared (first use in this function) arm-none-eabi-gcc: .Flashblinky.o: No such file or directory Target not created
why???
http://www.keil.com/forum/docs/thread12738.asp
