Sorry guys, I am just starting out on this IDE when MBED struggled to run Ticker and Uart together :(
after the export, the build shows this error : .\build\Nucleo_printf3.axf: error: L6002U: Could not open file mbed/TARGET_NUCLEO_F072RB/TOOLCHAIN_ARM_MICRO/stm32f0xx_hal_sp: No such file or directory
I checked the MBED and uV project folders, the file does not exist anywhere.
the project is attempting to use UART, Ticker, DAC
#include "mbed.h" Ticker toggle_led_ticker; Serial pc(SERIAL_TX, SERIAL_RX); // 9600 bauds, 8-bit data, no parity //Serial pc(PA_2, PA_3); // MBED won't run true serial ports ?? regardless here, all // outputs through USB virtual comm ports AnalogOut my_output(PA_4); DigitalOut myled(LED1); #define PI (3.141592653589793238462) #define AMPLITUDE (1.0) // x * 3.3V #define PHASE (PI * 1) // 2*pi is one period #define RANGE (4096/2) // 12 bits DAC #define OFFSET (4096/2) // 12 bits DAC // Configuration for sinewave output #define BUFFER_SIZE (360) uint16_t buffer[BUFFER_SIZE]; void calculate_sinewave(void); void toggle_led(void); void Ramp_DAC(void); void Dac_Sine_wave(void); int Dac_Output =0; int Buffer_pointer =0; int main() { calculate_sinewave(); //// toggle_led_ticker.attach(&toggle_led, 0.000006); //this is also output on Pin PA5, DAC2 //5.75uSec update gives fastest sinewave = 173.913kHz //// toggle_led_ticker.attach(&Ramp_DAC, 0.000006); // toggle_led_ticker.attach(&Dac_Sine_wave, 0.000006);// this stops the UART functioning in MBED int i = 1; pc.printf("Hello World !\n"); while(1) { wait(0.1); pc.printf("Step %d\n", i++); myled = !myled; } } void toggle_led() { myled = !myled; } void Ramp_DAC(void) { Dac_Output = Dac_Output + 2000; //if(Dac_Output >4096) Dac_Output=0; if(Dac_Output >=3000) Dac_Output=0; my_output.write_u16(Dac_Output); // my_output2.write_u16(Dac_Output); } void Dac_Sine_wave(void) { Buffer_pointer ++; if (Buffer_pointer >359) { Buffer_pointer =0; toggle_led(); } my_output.write_u16(buffer[Buffer_pointer]); //my_output2.write_u16(buffer[Buffer_pointer]/2); } // Create the sinewave buffer void calculate_sinewave(void) { for (int i = 0; i < BUFFER_SIZE; i++) { double rads = (PI * i)/180.0; // Convert degree in radian buffer[i] = (uint16_t)(AMPLITUDE * (RANGE * (cos(rads + PHASE))) + OFFSET); } }
