No subject
I am working on arm controller and am using stm32103EXL. When i try to build my project errors and warnings are displayed in my header files. But those errors are shown only in my project. If i try to use those header files for a different project it doesnt pose any pblm.. Please tell me a solution as soon as posssible.Rebuild target 'STM32F103 Flash'
assembling startup_stm32f10x_hd.s...
compiling system_stm32f10x.c...
compiling GLCD_16bitIF_STM32.c...
compiling LED.c...
compiling ADC.c...
compiling IRQ.c...
compiling Serial.c...
compiling Retarget.c...
compiling Blinky.c...
complex.h(98): warning: #223-D: function "sqrt" declared implicitly
complex.h(105): warning: #223-D: function "atan" declared implicitly
complex.h(112): warning: #223-D: function "cos" declared implicitly
complex.h(113): warning: #223-D: function "sin" declared implicitly
C:\Keil\ARM\ARMCC\bin\..\include\math.h(238): error: #159: declaration is incompatible with previous "atan" (declared at line 105 of "complex.h")
C:\Keil\ARM\ARMCC\bin\..\include\math.h(248): error: #159: declaration is incompatible with previous "cos" (declared at line 112 of "complex.h")
C:\Keil\ARM\ARMCC\bin\..\include\math.h(253): error: #159: declaration is incompatible with previous "sin" (declared at line 113 of "complex.h")
C:\Keil\ARM\ARMCC\bin\..\include\math.h(328): error: #159: declaration is incompatible with previous "sqrt" (declared at line 98 of "complex.h")
Target not created
  • This seems to be a problem in the complex.h header file that you are using. I believe that this is a local implementation and not the ANSI C standard header file.
    You should include math.h before the file complex.h or include math.h at the beginning of complex.h.
  • Yes. you are correct. this is only a local implementation file. I followed the steps as you said. But now the result is
    compiling LED.c...
    compiling ADC.c...
    compiling IRQ.c...
    linking...
    .\Flash\Blinky.axf: Error: L6218E: Undefined symbol system (referred from blinky.o).
    Target not created
    Really i cant understant wat problem lies with my code. Plz help me.
  • looks like you use a variable or function with the name 'system' that does not exist on an embedded target.
