Good afternoon,
Recently, I started using stm32 series of microcontrollers and had good experience with the stm32f429i discovery board. Now I tried programming the stm32f100c8t6 in keil using the standard peripherical library, but when I build the target I get these four errors and don't know how to fix them:
Build target 'Target 1' compiling main.c... linking... .\obj\Blink.axf: Error: L6200E: Symbol SystemCoreClock multiply defined (by system_stm32f10x_1.o and system_stm32f10x.o). .\obj\Blink.axf: Error: L6200E: Symbol AHBPrescTable multiply defined (by system_stm32f10x_1.o and system_stm32f10x.o). .\obj\Blink.axf: Error: L6200E: Symbol SystemCoreClockUpdate multiply defined (by system_stm32f10x_1.o and system_stm32f10x.o). .\obj\Blink.axf: Error: L6200E: Symbol SystemInit multiply defined (by system_stm32f10x_1.o and system_stm32f10x.o). Not enough information to list image symbols. Not enough information to list the image map. Finished: 2 information, 0 warning and 4 error messages. ".\obj\Blink.axf" - 4 Error(s), 0 Warning(s). Target not created.
Can you please help me to fix these errors?
I have added my project in GitHub, this is the link: github.com/.../STM32F100C8T6-Projects
Thanks, Pablo
Hello Pablo, just remove the file system_stm32f10x.c from the sys-folder, as otherwise it is included twice into your project.
Kind regards, Ralf
R.Kopsch Senior Applications Engineer ARM Germany GmbH
I appreciate your answer, that solved the problem. Thank you very much.
