I generated ds-5 license, when I installed server license, there is no server line in the license.dat, I put a server line in the file as instructed as follows
# ***** IMPORTANT NOTE *****
# This license is encrypted, editing may lead to it being made
# unusable.
# Instructions on how to install this license can be found
# on the ARM website:
# www.arm.com/.../licensemanagement.html
SERVER 127.0.0.1 002564da5c98 8224
INCREMENT RTSM_Pool_Apps armlmd 5.9 27-nov-2010 uncounted \
03D99CDBBE3A HOSTID=002564da5c98 ISSUER="ARM Limited" \
NOTICE="For evaluation purposes only" \
SN=LM01459-21162-252618603 SIGN="005B DC2B D03F 3920 8D30 6594 \
7B86 6773 E411 88EF 3DBA 6490 DA81 A0AF 9F2C 0AEA B1DE 7231 \
6E25 EC38 EE51 22E7 500D 94AA 15CC 7363 C373 935A 880A C025" \
SIGN2="1F77 85FF 95CA 34B3 0F1D C7A2 FB14 F0E3 A71D 43E3 1FD7 \
3042 37C5 6DDE 7E1F 08A8 8C1D CE45 0FB2 6DD0 3F90 64A9 6BFA \
6B58 B0C2 E253 6175 408B 78E7 9883"
INCREMENT RTSM_Pool_Pro armlmd 5.9 27-nov-2010 uncounted 6EF1C927929D \
HOSTID=002564da5c98 ISSUER="ARM Limited" NOTICE="For \
evaluation purposes only" SN=LM01459-21162-252618603 \
SIGN="0F62 D057 EC8B C315 D1CB EB98 2B64 63CC 33D2 D854 5DEE \
FFB2 1520 68B8 7A60 1C63 435D 2714 2977 AB8D B9E9 2428 ECF7 \
6869 6F03 EA61 6414 7C2A 6CF5 A678" SIGN2="1A9B 29D5 F045 A469 \
8C28 8379 8126 CDDA 7C58 C096 0119 A186 8331 5C28 5128 012F \
02EB 1DF2 205C 7CF3 A06F 5595 8F78 0281 1870 03B7 C203 CA96 \
FA10 75ED"
INCREMENT ds_debugger armlmd 5.9 27-nov-2010 uncounted 530FC9D2C7E9 \
SIGN="1AE2 FE8A 13F0 B761 1C3A 6D7E 6EBA 4E9D 75FF 6515 FF0F \
12DF E0A0 F0DA EE60 1156 EF2B 2CCB ABC3 CBE5 8405 52E6 71D6 \
80E2 5801 9921 2EFE 3931 F595 918C" SIGN2="1492 FC7D 6E8F 1FC7 \
CAB0 1A24 F263 AB4A 489C 4F15 5C05 59A7 7038 8204 94D6 05CD \
6D34 DF23 C53C 10EA 5F88 59FF 3545 8127 9E8A F50E 8D53 8D7D \
4FC3 CEBD"
INCREMENT ds_debugger_gdbserver armlmd 5.9 27-nov-2010 uncounted \
B2986575CBA6 HOSTID=002564da5c98 ISSUER="ARM Limited" \
SN=LM01459-21162-252618603 SIGN="0BB6 8E78 A2C3 BEB2 324B B6C5 \
B875 C0F6 628A 220B C757 DDD2 AF95 5CA3 A4FD 1FCD 449A 6016 \
FD8E 0DCA 2295 A19E 730C 2142 D44E BC52 7C74 720E 8E2A F39D" \
SIGN2="1E30 37E8 29E6 0A1A 7A70 7B23 E425 F33F 57FD 6B8E 084C \
7946 A72A 7B6C FB45 180F 9A67 0B33 ECCA BBBA E780 9C6B 0FD0 \
9A10 C1E5 C2AE 83CD EE83 9478 78A4"
INCREMENT ds_debugger_models armlmd 5.9 27-nov-2010 uncounted \
D2271D8435BB HOSTID=002564da5c98 ISSUER="ARM Limited" \
SN=LM01459-21162-252618603 SIGN="1580 CA4A 4163 917A 2EB3 2F65 \
342B 96A1 C79E 5855 C656 925C B6F8 9F26 8548 1814 1A8F 3097 \
99F0 863E 8257 61AC 5662 54B8 FE2F B001 99C4 848F E90A 63C2" \
SIGN2="097C 796E 08AA 4D94 C1E6 1573 F3AB 84C2 01C2 5828 AAB5 \
29D3 D53B 7C90 86AA 1924 2851 1C46 B361 E8C2 24B9 B5B4 B4A0 \
BAF0 0ECC A211 19CB 25A3 AE7E 2DD0"
INCREMENT ds_profiler armlmd 5.9 27-nov-2010 uncounted F29A96A81A46 \
SIGN="1F48 1840 1DFF E270 6F93 2CA7 6AAB 9EA0 3DEA F901 44D3 \
72B1 570F 1309 C608 1BD2 B05C 32A6 179C 73AA BB94 C110 EB13 \
1131 1AFA F269 4B53 7892 C782 3F1A" SIGN2="1287 E665 F0D2 0604 \
45AB E1C2 967F EF49 8ED1 1D34 9674 AF51 E59A 5CDB 7DED 0F03 \
07AF D444 E31E AF2E 51A8 8AC9 9AEB E6C4 4E97 7BD2 9A4C D3CE \
712C 6F1D"
After I run nohup lmgrd -c license.dat -l log.txt then tail -f log.txt, I see
20:59:42 (lmgrd) FLEXnet Licensing (v10.8.8.0 build 66122 i86_re3) started on 127.0.0.1 (linux) (11/1/2010) 20:59:42 (lmgrd) Copyright (c) 1988-2008 Acresso Software Inc. All Rights Reserved. 20:59:42 (lmgrd) US Patents 5,390,297 and 5,671,412. 20:59:42 (lmgrd) World Wide Web: http://www.acresso.com 20:59:42 (lmgrd) License file(s): license.dat 20:59:42 (lmgrd) lmgrd tcp-port 8224 20:59:42 (lmgrd) The license server manager has found no vendor daemons to start 20:59:42 (lmgrd) (There are no VENDOR (or DAEMON) lines in the license file), lmgrd exiting.
I don't know where it is not configured properly.
Notice that Keil Software Tech Support does not monitor this forum. I suggest that you contact Keil Tech Support directly via a problem report. Note the "Contact" link at the bottom left of this page. Al Bradford
Did you accidentally remove a line that starts with "DAEMON" from your license.dat file?
No, I don't see DAEMOM line.
Oh, I think I see now: the eval license is node-locked (e.g. has HOSTID=...) and someone has tried to make it floating by adding the SERVER line -- that won't work. You should be able to use the original eval license (without the SERVER line) by putting the pathname of the license in the ARMLMD_LICENSE_FILE environment variable.
I use it in Linux, How can I get node-locked license?
The eval license above (with the SERVER line removed) *is* node-locked (HOSTID=...). All DS-5 eval licenses are node-locked.
If the license above is locked to the wrong machine then you'll need to get a new eval license. See <infocenter.arm.com/.../index.jsp about finding the right hostid for a linux machine. Since you've already had an eval license, silver.arm.com may be reluctant to give you another; you may need to email license.support@arm.com (or use your existing support case) explaining the problem and supplying the new hostid.
I got ds-5 to work by the floating license server. But the new ds-5 has still problem to debug the static library. It works fine with main application. But once the debugger enters a function in a static library. The debugging indicator always jumps forward and backward. This issue has been reported before. It seems it is still there.
This should really be discussed in a different/new thread. Do you have a URL to a thread where it was reported before?
What optimization level was the static library built with? It's not unusual for the PC to move in unexpected ways at higher optimization levels.
