Please help with RTX
I'm new to ARM RTX. So i tried to compile the example RTX_ex2 in the RL folder of keil.. Its default controller was LPC2129. It compiled with it. But mine is LPC2148. So I tried to change it. Now it doesnt work anymore. Even when i tried to change it back to 2129 it doesnt work. It shows following errors. Please help.
.\Obj\RTX_ex2.axf: Error: L6218E: Undefined symbol os_sys_init0 (referred from rtx_ex2.o).
.\Obj\RTX_ex2.axf: Error: L6218E: Undefined symbol os_tsk_create0 (referred from rtx_ex2.o).
.\Obj\RTX_ex2.axf: Error: L6218E: Undefined symbol os_tsk_prio (referred from rtx_ex2.o).
.\Obj\RTX_ex2.axf: Error: L6218E: Undefined symbol os_tsk_self (referred from rtx_ex2.o).
.\Obj\RTX_ex2.axf: Error: L6218E: Undefined symbol SWI_Handler (referred from startup.o).
  • Why don't you try example for your chip in folder:
    \ARM\Boards\Keil\MCB2140\RTX_Blinky\
  • To the OP:
    Once you change the MCU setting, the Operating System Setting will be set to default. You need to config the Operating System Setting again.
    Check the "Options of Target" -> "Operating System:"
  • Thanks.. will try it. I will ask for more help if u dont mind. :)
  • I'm getting this, and I'm tired of trying to track it down...
    Build target 'CM3_RTX'
    compiling stm32f10x_it.c...
    compiling main.c...
    compiling RTX_Conf_CM.c...
    compiling core_cm3.c...
    compiling misc.c...
    compiling stm32f10x_dma.c...
    compiling stm32f10x_exti.c...
    compiling stm32f10x_fsmc.c...
    compiling stm32f10x_gpio.c...
    compiling stm32f10x_i2c.c...
    compiling stm32f10x_rcc.c...
    compiling stm32f10x_sdio.c...
    compiling stm32f10x_spi.c...
    compiling stm32f10x_usart.c...
    compiling system_stm32f10x.c...
    assembling startup_stm32f10x_hd.s...
    compiling stm32_eval.c...
    compiling stm3210e_eval_lcd.c...
    linking...
    CM3_RTX.axf: Error: L6218E: Undefined symbol os_fifo (referred from p1238-3).
    CM3_RTX.axf: Error: L6218E: Undefined symbol os_fifo_size (referred from p1238-3).
    CM3_RTX.axf: Not enough information to produce a FEEDBACK file.
    CM3_RTX.axf: Not enough information to list image symbols.
    CM3_RTX.axf: Not enough information to list the image map.
    CM3_RTX.axf: Finished: 3 information, 0 warning and 2 error messages.
    Target not created
    What am I missing? (I feel so lame in asking, but again, I'm tired of searching, especially if somebody out there has The Answer. And yes, I know it might not be enough information).
    --Cpt. Vince Foster
    2nd Cannon Place
    Fort Marcy Park, VA
  • Testing 123
    (the post I did didn't show up)
    --Cpt. Vince Foster
    2nd Cannon Place
    Fort Marcy Park, VA
