No HID interrupt IN transfers
For a LPC23xx device, I'm adding HID besides MSC. I got everything working fine, except for HID interrupt IN transfers. So I can get and set HID reports via control transfers. Also, I can set reports via interrupt OUT transfers, but not IN.
Using USBlyzer, I diagnosed the packet stream. As soon as I attach my device, I do see two interrupt IN transfer attempts at 01:00:81 (C:I:E). If my host application reads EP 1, USBlyzer does not show any packets passing by.
I'm a bit out of options. Does anyone have a clue where to look for a fix?
Thanks,
Mark
Connection Status Device connected
Current Configuration 1
Speed Full
Device Address 3
Number Of Open Pipes 4
Device Descriptor Swinxs Game Console
Offset Field Size Value Description
0 bLength 1 12h
1 bDescriptorType 1 01h Device
2 bcdUSB 2 0200h USB Spec 2.0
4 bDeviceClass 1 00h Class info in Ifc Descriptors
5 bDeviceSubClass 1 00h
6 bDeviceProtocol 1 00h
7 bMaxPacketSize0 1 40h 64 bytes
8 idVendor 2 C251h Keil Software, Inc.
10 idProduct 2 1708h
12 bcdDevice 2 0203h 2.03
14 iManufacturer 1 04h "Swinxs BV "
15 iProduct 1 20h "Swinxs Game Console"
16 iSerialNumber 1 48h "000050020801"
17 bNumConfigurations 1 01h
Configuration Descriptor 1 Bus Powered, 300 mA
0 bLength 1 09h
1 bDescriptorType 1 02h Configuration
2 wTotalLength 2 0040h
4 bNumInterfaces 1 02h
5 bConfigurationValue 1 01h
6 iConfiguration 1 00h
7 bmAttributes 1 80h Bus Powered
 4..0: Reserved  ...00000
 5: Remote Wakeup  ..0.....  No
 6: Self Powered  .0......  No, Bus Powered
 7: Reserved (set to one)
(bus-powered for 1.0)  1.......
8 bMaxPower 1 96h 300 mA
Interface Descriptor 0/0 HID, 2 Endpoints
0 bLength 1 09h
1 bDescriptorType 1 04h Interface
2 bInterfaceNumber 1 00h
3 bAlternateSetting 1 00h
4 bNumEndpoints 1 02h
5 bInterfaceClass 1 03h HID
6 bInterfaceSubClass 1 00h
7 bInterfaceProtocol 1 00h
8 iInterface 1 80h "Swinxs HID"
HID Descriptor
0 bLength 1 09h
1 bDescriptorType 1 21h HID
2 bcdHID 2 0110h 1.10
4 bCountryCode 1 00h
5 bNumDescriptors 1 01h
6 bDescriptorType 1 22h Report
7 wDescriptorLength 2 0045h 69 bytes
Endpoint Descriptor 81 1 In, Interrupt
0 bLength 1 07h
1 bDescriptorType 1 05h Endpoint
2 bEndpointAddress 1 81h 1 In
3 bmAttributes 1 03h Interrupt
 1..0: Transfer Type  ......11  Interrupt
 7..2: Reserved  000000..
4 wMaxPacketSize 2 0001h 1 byte
6 bInterval 1 00h
Endpoint Descriptor 01 1 Out, Interrupt
0 bLength 1 07h
2 bEndpointAddress 1 01h 1 Out
4 wMaxPacketSize 2 0006h 6 bytes
6 bInterval 1 00h
Interface Descriptor 1/0 Mass Storage, 2 Endpoints
0 bLength 1 09h
2 bInterfaceNumber 1 01h
5 bInterfaceClass 1 08h Mass Storage
6 bInterfaceSubClass 1 06h SCSI Transparent Command Set
7 bInterfaceProtocol 1 50h Bulk-Only Transport
8 iInterface 1 62h "Swinxs Storage"
Endpoint Descriptor 82 2 In, Bulk, 64 bytes
0 bLength 1 07h
2 bEndpointAddress 1 82h 2 In
3 bmAttributes 1 02h Bulk
 1..0: Transfer Type  ......10  Bulk
4 wMaxPacketSize 2 0040h 64 bytes
6 bInterval 1 00h
Endpoint Descriptor 02 2 Out, Bulk, 64 bytes
0 bLength 1 07h
2 bEndpointAddress 1 02h 2 Out
6 bInterval 1 00h
Interface 0 HID Report Descriptor
Item Tag (Value) Raw Data
Usage Page (Vendor-Defined 1) 06 00 FF
Usage (Undefined) 09 00
Collection (Application) A1 01
    Usage Page (Vendor-Defined 2) 06 01 FF
    Usage (Vendor-Defined 1) 09 01
    Logical Minimum (1) 15 01
    Logical Maximum (16777215) 27 FF FF FF 00
    Report Count (1) 95 01
    Report Size (24) 75 18
    Input (Data,Var,Abs,NWrp,Lin,Pref,NNul,Bit) 81 02
    Usage (Vendor-Defined 2) 09 02
    Report Size (16) 75 10
    Usage Minimum (Vendor-Defined 1) 19 01
    Usage Maximum (Vendor-Defined 3) 29 03
    Logical Minimum (0) 15 00
    Logical Maximum (1) 25 01
    Report Count (3) 95 03
    Report Size (1) 75 01
    Report Size (5) 75 05
    Input (Cnst,Ary,Abs) 81 01
    Usage Page (Vendor-Defined 3) 06 02 FF
    Usage (Vendor-Defined 16) 09 10
    Logical Maximum (100) 25 64
    Report Size (8) 75 08
    Output (Data,Var,Abs,NWrp,Lin,Pref,NNul,NVol,Bit) 91 02
End Collection C0
  • Endpoint Descriptor 81 1 In, Interrupt  --- HID interrupt IN EP
    0 bLength 1 07h
    6 bInterval 1 00h
    bInterval field of EP1 is 00h.
    Set it more than 1 (ms)
    Tsuneo
  • Ah, you have to fix EP1 OUT, too.
    6 bInterval 1 00h
    Tsuneo
  • Earlier I did set the interval values for the EP1 descriptors to 0x20. So on your advise, I restored these values. The reason I set those to 0 was because I saw the following SetIdle packet passing by:
    0 bmRequestType 1 21h
     4..0: Recipient  ...00001  Interface
     6..5: Type  .01.....  Class
     7: Direction  0.......  Host-to-Device
    1 bRequest 1 0Ah Set Idle
    2 wValue.LowByte 1 00h Report ID
    3 wValue.HiByte 1 00h Infinite Idle Rate
    4 wIndex 2 0000h Interface
    6 wLength 2 0000h
    The OS HID driver sent it to my device. So I thought I could set it 0 already in the EP descriptor.
    Anyway, even if I define bInterval by 0x20, I still can't send interrupt IN transfers to my device. The MSC interface has no problems sending IN-OUT bulk transfers. Strange... I used Jan Axelsson's Generic HID tester to test.
  • > The reason I set those to 0 was because I saw the following SetIdle packet passing by:
    Just after enumeration,
    Windows puts SetIdle( 0 ) - indefinite, the device gives the timing when it sends input report
    MacOSX SetIdle( 9 ) - 36 ms,
    and Linux nothing.
    bInterval of the interrupt endpoints are chosen independently from OS.
    The requirement of your application determines the value.
    When your application needs to send data from device frequently, smaller value is assigned. Otherwise, greater value.
    Anyway, 0 isn't allowed for bInterval of interrupt endpoints.
    It is the device side problem, on the interrupt IN endpoint handling.
    Even if your PC application doesn't read any input report, HID device driver (*1) repeats IN transactions at the specified interval without break.
    If you don't see any IN packet on the sniffer,
    - Your firmware puts nothing to the endpoint.
    If you see IN packet on the sniffer, but don't see any input report on the application,
    - Your firmware puts some data, but the format (data length) is wrong. The packet is dropped by the device driver.
    I'll show you how HID example handles the interrupt IN endpoint.
    This is an excerpt from KEIL HID implementation.
    LPC2368 / LPC2378 USB HID (Human Interface Device) Example
    http://www.keil.com/download/docs/335.asp
    usbuser.c
    #if USB_CONFIGURE_EVENT
    void USB_Configure_Event (void) {
      if (USB_Configuration) {                  /* Check if USB is configured */
        GetInReport();
        USB_WriteEP(0x81, &InReport, sizeof(InReport));
    #endif
    void USB_EndPoint1 (DWORD event) {
      switch (event) {
        case USB_EVT_IN:
          GetInReport();
          break;
    USB_Configure_Event() is called when Set_Configuration request comes from host on enumeration. In this routine, an input report is loaded to the EP1 IN buffer using USB_WriteEP(). This report is the first one. When host starts to repeat IN transactions just after enumeration, this report is sent to the host. And then, USB interrupt occurs at the IN EP1.
    On this interrupt, USB_EndPoint1() is called.
    This routine fills the endpoint buffer with a report using USB_WriteEP().
    This report is sent to host at the next IN transaction after the specified interval (bInterval).
    Another endpoint interrupt occurs, and USB_EndPoint1() is called again.
    In this way, USB_EndPoint1() is called repeatedly, at bInterval.
    If you put nothing to the endpoint buffer in USB_EndPoint1(), what happens?
    No report is sent to the host, and no endpoint interrupt occurs.
    The sequence stops, USB_EndPoint1() is never called any more,
    until you fill the endpoint buffer with USB_WriteEP().
    I suppose this is your story, isn't it?
    (*1) Actually, it is the host controller which repeats IN transactions periodically. HID device driver keeps IN transfer, putting one after another.
    Tsuneo
  • > I suppose this is your story, isn't it?
    Tsuneo, right on the spot! Indeed filling in the code for USB_Configure_Event() started the EP1 IN polling. Thank you a lot for pointing it out to me, I don't think I would have found it myself.
    Actually, I had to increase EP1-IN wMaxPacketSize from 6 (the size of the report) to 8. I was under the impression that wMaxPacketSize should be large enough to contain the report size (in my case 6). Can you advise me for the optimal wMaxPacketSize?
    Another issue I encounter is that my application seems to miss some GetReports(). Probably because my application polls the reports less often then the host does. But I'm convident I can sort this out myself :)
  • The evil of this HID example is that it gives a fixed idea - read/write of endpoint buffer should be done just in the endpoint ISR. It's wrong. Rather, read/write in the endpoint ISR is a rare case in the real world code.
    Consider on UART. If you would see a UART example in which UART TX ISR seamlessly puts character one after another, what do you think of the quality of the example? Is the example practical? Never. You'll take it that a beginner have made the example.
    The quality of this Keil HID example is in such a level. Not just for Keil. Still low-quality USB examples have been spread out from other compiler/ chip vendors. Isn't it the time to brush them up?
    You may write to the IN EP buffer using USB_WriteEP(), any where, any timing as you like (unless the EP buffer is still occupied by the last write). For example, you may write to the IN EP buffer in a timer ISR, which scans ports for keypads. You may write in ADC ISR, just when a sensor input shows change.
    These ISRs should have the same priority (FAST/SLOW) as USB ISR, so that USB_WriteEP() calls from both ISRs don't interrupt each other. When you call USB_WriteEP() from main line code, disable USB interrupt temporarily around USB_WriteEP() call. Or make a SWI which calls USB_WriteEP().
    wMaxPacketSize field on endpoint descriptor is set to greater or equal to the packet size you exchange. When you exchange 6 bytes, wMaxPacketSize is set to 6, or more. Greater size doesn't do any harm but no benefit. It just reserves more bandwidth on the bus.
    Get_Report request is sent from host just when PC app calls HidD_GetInputReport() (Windows XP and later). When the app calls it synchronously, the app is blocked until this call finishes. Then, you'd not miss it.
    ReadFile() pulls an input report from the input buffer on the HID PC device driver, which is filled with the reports carried from the interrupt IN endpoint on the device. The number of input reports held in this input buffer is altered using HidD_SetNumInputBuffers(). The default is 32 reports.
    Tsuneo
  • > You may write to the IN EP buffer using USB_WriteEP(), any where, any timing as you like
    Aha, now I see that it's a bit tricky to use the ISR to fill the buffer. I rewrote the device firmware to us USB_WriteEP() asynchronously: as soon as data for a new report becomes available, I write a report immediately. And my code got much cleaner now :)
    If I'm right, __swi is only available for the RTX kernel, which we don't use. So that leaves my with two options:
    VICIntEnClr |= 1 << VIC_USB;   /* Disable Interrupt */
    VICIntEnable |= 1 << VIC_USB;  /* Enable Interrupt */
    or
    int was_masked = __disable_irq();
    if (!was_masked) __enable_irq();
    Is one way preferred over the other?
    I found the solution to my problem. I defined the packet correctly. But because I used a char* as type for InReport and OutReport, these variables or byte aligned. What I didn't knew was that USB_WriteEP() really needs the buffer to be long-aligned (at least in the implementation I use). So adding __align(4) to the declarations fixed the bug.
    Yes indeed. My application should read all available input reports every cycle, not just one. Then I'll receive all reports and won't miss one.
    Thank you Tsuneo, you helped me again! I'm about to round up my project as the code seems stable now :)
  • No, __swi isn't only available with RTX. The main difference is that RTX reserves a couple of numbers. If I remember correct, __swi(0) to __swi(7) are served by RTX.
  • Hello,
    Use of __swi does not depend on RTX.
    The difference is that RTX already contains a SWI handler and SWI functions __swi(0) to __swi(7) are reserved.
    If you do not use RTX and want to use SWI functions than you must include an own SWI handler.
    Please check example C:\Keil\ARM\Examples\SWI.
    Best Regards,
    Martin Guenther
  • > now I see that it's a bit tricky to use the ISR to fill the buffer.
    Natural.
    The endpoint ISR is triggered by the host.
    In most cases, the timing isn't suitable for the device side.
    Devices want to pass a packet to the USB engine, just at the timing when it is available on the device.
    And then, the code flow gets straighten out on the firmware source.
    When you take this strategy, you don't need to put a packet in USB_Configure_Event(), any more.
    To make this strategy robust,
    Shorter bInterval of the endpoint descriptor
    - less than or equal to 1/3 of expected interval on the firmware.
    Suppose that, you have keypad scan in 20 ms interval. Just when any key change occurs, the result is sent to host using an input report over the HID interrupt IN EP. The least interval of the report is 20 ms. (with debounce, it may be longer, though) In this case, bInterval is set to 6 ms (<= 20 / 3), or less.
    The magic number 3 derives as follows,
    The host repeats to poll the IN EP at bInterval (*1) using IN transactions. When noise disturbs the transaction, host retires it after bInterval. Host repeats three error-retry (including the first one - "Three strikes, OUT" rule), while error occurs. Until host succeeds, the EP buffer is occupied by the last packet. The transfer delays for three bInterval duration, at most.
    (*1)
    USB spec doesn't guarantee that the IN EP is polled exactly at bInterval. It allows that the actual polling interval is equal to or less than bInterval.
    Actual interval is determined by the host controller spec and device driver implementation on the host side.
    OHCI clearly notes that it reduces bInterval to 1, 2, 4, 8, 16, 32 ms
    The Other inplementations of host controllers also follow this rule.
    OpenHCI - OHCI spec (hcir1_0a.pdf)
    download.microsoft.com/.../hci_1.exe
    5.2.7.2 Interrupt
    The lower five bits of the current frame number is used as an index into an array of 32 interrupt Endpoint Descriptor lists found in the HCCA. This means each list is revisited once every 32 ms.
    5.2.7.2.1 Polling Rate
    Interrupt Endpoint Descriptors have a minimum rate for which they need to be scheduled. When this information is provided to Host Controller Driver, it determines the closest power of 2 rate below the endpoints requirement and determines which scheduling queue for that rate has the smallest committed bandwidth.
    Tsuneo
  • You'll find __swi version of USB_WriteEP in Keil USBCDC example, as follows.
    C:\Keil\ARM\Boards\Keil\MCB2300\USBCDC
    usbhw.h
    extern DWORD __swi(8) USB_WriteEP (DWORD EPNum, BYTE *pData, DWORD cnt);
    usbhw.c
     *  Write USB Endpoint Data
     *    Parameters:      EPNum: Endpoint Number
     *                       EPNum.0..3: Address
     *                       EPNum.7:    Dir
     *                     pData: Pointer to Data Buffer
     *                     cnt:   Number of bytes to write
     *    Return Value:    Number of bytes written
    DWORD __SWI_8              (DWORD EPNum, BYTE *pData, DWORD cnt) {
    //DWORD USB_WriteEP (DWORD EPNum, BYTE *pData, DWORD cnt) {
      DWORD n;
      USB_CTRL = ((EPNum & 0x0F) << 2) | CTRL_WR_EN;
      TX_PLENGTH = cnt;
      for (n = 0; n < (cnt + 3) / 4; n++) {
        TX_DATA = *((__packed DWORD *)pData);
        pData += 4;
      USB_CTRL = 0;
      WrCmd(CMD_SEL_EP(EPAdr(EPNum)));
      WrCmd(CMD_VALID_BUF);
      return (cnt);
    In the background, SWI.s is dragged in from RL_ARM,
    ;/* SWI.S: SWI Handler                                                        */
    ;/* This file is part of the uVision/ARM development tools.                   */
    ;/* Copyright (c) 2005-2006 Keil Software. All rights reserved.               */
    ;/* This software may only be used under the terms of a valid, current,       */
    ;/* end user licence from KEIL for a compatible version of KEIL software      */
    ;/* development tools. Nothing else gives you the right to use this software. */
    T_Bit           EQU     0x20
                    PRESERVE8                      ; 8-Byte aligned Stack
                    AREA    SWI_Area, CODE, READONLY
                    ARM
                    EXPORT  SWI_Handler
    SWI_Handler
                    STMFD   SP!, {R12, LR}         ; Store R12, LR
                    MRS     R12, SPSR              ; Get SPSR
                    STMFD   SP!, {R8, R12}         ; Store R8, SPSR
                    TST     R12, #T_Bit            ; Check Thumb Bit
                    LDRNEH  R12, [LR,#-2]          ; Thumb: Load Halfword
                    BICNE   R12, R12, #0xFF00      ;        Extract SWI Number
                    LDREQ   R12, [LR,#-4]          ; ARM:   Load Word
                    BICEQ   R12, R12, #0xFF000000  ;        Extract SWI Number
                    LDR     R8, SWI_Count
                    CMP     R12, R8
                    BHS     SWI_Dead               ; Overflow
                    ADR     R8, SWI_Table
                    LDR     R12, [R8,R12,LSL #2]   ; Load SWI Function Address
                    MOV     LR, PC                 ; Return Address
                    BX      R12                    ; Call SWI Function
                    LDMFD   SP!, {R8, R12}         ; Load R8, SPSR
                    MSR     SPSR_cxsf, R12         ; Set SPSR
                    LDMFD   SP!, {R12, PC}^        ; Restore R12 and Return
    SWI_Dead        B       SWI_Dead               ; None Existing SWI
    SWI_Cnt         EQU    (SWI_End-SWI_Table)/4
    SWI_Count       DCD     SWI_Cnt
                    IMPORT  __SWI_8
    SWI_Table
                    DCD     SWI_Dead               ; SWI 0 Function Entry used by RTX
                    DCD     SWI_Dead               ; SWI 1 Function Entry used by RTX
                    DCD     SWI_Dead               ; SWI 2 Function Entry used by RTX
                    DCD     SWI_Dead               ; SWI 3 Function Entry used by RTX
                    DCD     SWI_Dead               ; SWI 4 Function Entry used by RTX
                    DCD     SWI_Dead               ; SWI 5 Function Entry used by RTX
                    DCD     SWI_Dead               ; SWI 6 Function Entry used by RTX
                    DCD     SWI_Dead               ; SWI 7 Function Entry used by RTX
                    DCD     __SWI_8                ; SWI 8 Function Entry
    SWI_End
                    END
    Also, LPC2300.s is modified a little to support SWI (SVC)
    LPC2300.s
    SVC_Stack_Size  EQU     0x00000100
    Vectors         LDR     PC, Reset_Addr
                    LDR     PC, Undef_Addr
    IRQ_Addr        DCD     IRQ_Handler
    FIQ_Addr        DCD     FIQ_Handler
                    IMPORT  SWI_Handler
    Undef_Handler   B       Undef_Handler
    ;SWI_Handler     B       SWI_Handler
    PAbt_Handler    B       PAbt_Handler
    DAbt_Handler    B       DAbt_Handler
    IRQ_Handler     B       IRQ_Handler
    FIQ_Handler     B       FIQ_Handler
    Tsuneo
