Vectors LDR PC, Reset_Addr LDR PC, Undef_Addr LDR PC, SWI_Addr LDR PC, PAbt_Addr LDR PC, DAbt_Addr NOP ; Reserved Vector LDR PC, IRQ_Addr
LDR PC, [PC, #-0x0120] ; Vector
from VicVectAddr
LDR PC, FIQ_Addr
Reset_Addr DCD Reset_Handler
Undef_Addr DCD Undef_Handler
SWI_Addr DCD 0 PAbt_Addr DCD PAbt_Handler
DAbt_Addr DCD DAbt_Handler
DCD 0 ; Reserved Address
IRQ_Addr DCD 0
FIQ_Addr DCD FIQ_Handler
Undef_Handler B Undef_Handler
SWI_Handler B SWI_Handler
PAbt_Handler B PAbt_Handler
DAbt_Handler B DAbt_Handler
;IRQ_Handler B IRQ_Handler
FIQ_Handler B FIQ_Handler
; Reset Handler
EXPORT Reset_Handler
Reset_Handler
; Setup Stack for each mode
LDR R0, =Stack_Top
; Enter Undefined Instruction Mode and set its Stack
Pointer
MSR CPSR_c,
#Mode_UND:OR:I_Bit:OR:F_Bit
MOV SP, R0
SUB R0, R0, #UND_Stack_Size
; Enter Abort Mode and set its Stack Pointer
#Mode_ABT:OR:I_Bit:OR:F_Bit
SUB R0, R0, #ABT_Stack_Size
; Enter FIQ Mode and set its Stack Pointer
#Mode_FIQ:OR:I_Bit:OR:F_Bit
SUB R0, R0, #FIQ_Stack_Size
; Enter IRQ Mode and set its Stack Pointer
#Mode_IRQ:OR:I_Bit:OR:F_Bit
SUB R0, R0, #IRQ_Stack_Size
; Enter Supervisor Mode and set its Stack Pointer
#Mode_SVC:OR:I_Bit:OR:F_Bit
SUB R0, R0, #SVC_Stack_Size
; Enter User Mode and set its Stack Pointer
MSR CPSR_c, #Mode_USR
SUB SL, SP, #USR_Stack_Size
; IMPORT TargetResetInit
; BL TargetResetInit
; Enter the C code
IMPORT __main
LDR R0, =__main
BX R0
; User Initial Stack & Heap
AREA |.text|, CODE, READONLY
IMPORT __use_two_region_memory
EXPORT __user_initial_stackheap __user_initial_stackheap
LDR R0, = Heap_Mem
LDR R1, =(Stack_Mem +
USR_Stack_Size)
LDR R2, = (Heap_Mem +
Heap_Size)
LDR R3, = Stack_Mem
BX LR
END
This is my Startup code. While debugging the execution stuck at "Enter the C Code part" Instead of jump to main,program execution enter to below loop
0x0000012C E2522010 SUBS R2,R2,#0x00000010 0x00000130 28A10078 STMCSIA R1!,{R3-R6} 0x00000134 8AFFFFFC BHI 0x0000012C
I cant see the corresponding C code of this loop. Plz give some suggestions or solution to this problem
