PSB2193
Why Keil refuses to compile if I use the standard libraries?
The Listings of the ravine and program below?
That me it is necessary to do to correct these errors?
I use:
IDE-Version:
µVision3 V3.50
Copyright (c) Keil Elektronik GmbH / Keil Software, Inc. 1995 - 2007
Tool Version Numbers:
Toolchain Path: D:\Soft\Radio\Keil\Keil\C166\BIN\
EC++ Compiler: EC166.Exe V1.09b
C Compiler: C166.Exe V6.06
Assembler: A166.Exe V5.21
Linker/Locator: L166.Exe V5.22
Librarian: LIB166.Exe V4.26
Hex Converter: OH166.Exe V4.7a
CPU DLL: S166.DLL V2.52
Dialog DLL: D167.DLL V2.48
µVision3 Build Log
Project:
D:\Документы\Keil\INCA-P\inca-p.uv2
Project File Date:  03/14/2007
Output:
Build target 'INCA-P'
compiling main.C...
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(78): error C155: 'XBCON3': invalid base address
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(136): error C155: 'EXICON': invalid base address
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(180): error C155: 'DP0L': invalid base address
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(181): error C155: 'DP0H': invalid base address
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(182): error C155: 'DP1L': invalid base address
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(183): error C155: 'DP1H': invalid base address
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(200): error C155: 'ODP2': invalid base address
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(201): error C155: 'ODP3': invalid base address
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(202): error C155: 'ODP6': invalid base address
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(203): error C155: 'ODP7': invalid base address
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(205): error C155: 'XP0IC': invalid base address
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(206): error C155: 'XP1IC': invalid base address
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(207): error C155: 'XP2IC': invalid base address
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(208): error C155: 'XP3IC': invalid base address
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(209): error C155: 'RP0H': invalid base address
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(210): error C67: 'XP0IC': undefined identifier
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(211): error C67: 'XP0IC': undefined identifier
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(212): error C67: 'XP1IC': undefined identifier
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(213): error C67: 'XP1IC': undefined identifier
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(214): error C67: 'XP2IC': undefined identifier
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(215): error C67: 'XP2IC': undefined identifier
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(216): error C67: 'XP3IC': undefined identifier
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(217): error C67: 'XP3IC': undefined identifier
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(237): error C155: 'P2ALTSEL0': invalid base address
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(238): error C155: 'P2ALTSEL1': invalid base address
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(239): error C155: 'P3ALTSEL0': invalid base address
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(240): error C155: 'P3ALTSEL1': invalid base address
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(241): error C155: 'P6ALTSEL0': invalid base address
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(242): error C155: 'P7ALTSEL0': invalid base address
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(282): error C155: 'S0TBIC': invalid base address
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(295): error C67: 'S0TBIC': undefined identifier
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(296): error C67: 'S0TBIC': undefined identifier
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(302): error C155: 'SSCCLC': invalid base address
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(306): error C155: 'SSCTB': invalid base address
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(307): error C155: 'SSCRB': invalid base address
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(308): error C155: 'SSCBR': invalid base address
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(433): error C155: 'ICINTEIE': invalid base address
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(433): error C156: 'ICINTEIE': invalid 'sbit' declaration
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(435): error C155: 'ICINTEIR': invalid base address
D:\SOFT\RADIO\KEIL\KEIL\C166\INC\REGINCA.H(435): error C156: 'ICINTEIR': invalid 'sbit' declaration
assembling START167.A66...
Target not created
#include <stdio.h> /* standard I/O .h-file */
#include <RegINCA.h> /* &#1089;&#1087;&#1077;&#1094;&#1080;&#1072;&#1083;&#1100;&#1085;&#1099;&#1077; &#1092;&#1091;&#1085;&#1082;&#1094;&#1080;&#1080; PSB21493 */ /****************/
/* main program */
void main (void) { while (1) {}
  • My be you shouldn't use russian chars in foulder name?
  • Has Saved in file without russian letters in name. Did Not help.
  • What does
    "D:\&#1044;&#1086;&#1082;&#1091;&#1084;&#1077;&#1085;&#1090;&#1099;\Keil\INCA-P\inca-p.uv2"
    mean?
    It looks like project saved in "&#1044;&#1086;&#1082;&#1091;&#1084;&#1077;&#1085;&#1090;&#1099;\Keil\INCA-P\" folder.
    "&#1044;&#1086;&#1082;&#1091;&#1084;&#1077;&#1085;&#1090;&#1099;" - russian chars.
  • Here is I have saved the project in file without use the russian letters in name, but mistakes don't care there is:
    µVision3 Build Log
    Project:
    D:\keil\incap\incap.uv2
    Project File Date:  03/16/2007
    Output:
    Build target 'inca-p'
    compiling main.C...
    Target not created
  • My Keil programm instslled in C:\Keil
    Your - D:\SOFT\RADIO\KEIL\KEIL\
    My be you should try to reinstall it in default folder?
    No other ideas
  • Please enter MOD167 under
    Project - Options - C166 - Misc and
    Project - Options - A166 - Misc
    Then it should work just fine.
