Hi, I'm programming for a Cypress EZ-USB FX2 platform, and I'm adding onto the default firmware. I'm having some problems compiling some code, and I'm wondering if I'm running into space limitations already.
First of all, I get warnings when I try to initialize the I2C interface by calling
EZUSB_InitI2C();
I get the warning message
*** WARNING L16: UNCALLED FUNCTION, IGNORED FOR OVERLAY PROCESS NAME: _EZUSB_WAITFOREEPROMWRITE/I2C *** WARNING L16: UNCALLED FUNCTION, IGNORED FOR OVERLAY PROCESS NAME: _EZUSB_WRITEI2C_?I2C *** WARNING L16: UNCALLED FUNCTION, IGNORED FOR OVERLAY PROCESS NAME: _EZUSB_READI2C_?I2C Program Size: data=112.4 xdata=6830 const=216 code=8870
Next, when I try to add in another for loop as below
for (i=0;i<16;i++) EZUSB_ReadI2C(ZTBL_ADDR+i, 0x01, z_table[i]);
I am unable to compile. I get the following error messages on top of the warning message
*** ERROR L107: ADDRESS SPACE OVERFLOW SPACE: CODE SEGMENT: ?L?COM001A LENGTH: 00000BH *** ERROR L107: ADDRESS SPACE OVERFLOW SPACE: CODE SEGMENT: ?L?COM0022 LENGTH: 000009H *** ERROR L138: CODE GENERATION: PROBLEM WHEN PROCESSING INSTRUCTIONS CAUSE: JUMP TARGET OUT OF RANGE ADDRESS: 0750H *** ERROR L138: CODE GENERATION: PROBLEM WHEN PROCESSING INSTRUCTIONS CAUSE: JUMP TARGET OUT OF RANGE ADDRESS: 0761H *** ERROR L138: CODE GENERATION: PROBLEM WHEN PROCESSING INSTRUCTIONS CAUSE: JUMP TARGET OUT OF RANGE ADDRESS: 0785H *** ERROR L138: CODE GENERATION: PROBLEM WHEN PROCESSING INSTRUCTIONS CAUSE: JUMP TARGET OUT OF RANGE ADDRESS: 07B0H Program Size: data=112.4 xdata=6830 const=216 code=8993 Target not created
Have I run out of space already?
Thanks!
