Need timer.h and lcd.h which suits the program given below
hello everyone,
im doin my engineering project on AUTOMATIC SPEED CONTROL OF AUTOMOBILES.i am using AT89C52 and 16x2 lcd display.
i have the C program for it,but i need Timer.h & Lcd.h for it to work....
plz help me find it or create one header fle for the program below.....
/* RF id transmitter for vehicle SCHOOL ZONE & HOSPITAL ZONE */
#include <stdio.h>
#include <lcd.h>
#include <timer.h>
PORT: TX_PORT = P2;
PORT: LCD_PORT = P0;
PIN: ID_SET_KEY = P1.3;
PIN: IN_A0 = P3.3;
PIN: IN_A1 = P3.4;
unsigned char send_id;
select_id_sw()
if( (IN_A0 == 0) && (IN_A1 == 0 ) )
uputs(16,0,16,"0:NO ZONE LIMIT ");
send_id = 0;
if( (IN_A0 == 1) && (IN_A1 == 0 ) )
uputs(16,0,16,"1 SCHOOL ZONE ");
send_id = 1;
if( (IN_A0 == 0) && (IN_A1 == 1 ) )
uputs(16,0,16,"2: HOSPITAL ZONE");
send_id = 2;
if( (IN_A0 == 1) && (IN_A1 == 1 ) )
uputs(16,0,16,"3:NO ZONE LIMIT ");
send_id = 3;
main()
unsigned int d;
uputs(0,0,16, " VECHILE SPEED ");
uputs(16,0,16," ZONE LIMIT TX ");
for(d=0; d < 60000; d++);
uputs(0,0,16, " WELCOME TO ECE ");
uputs(16,0,16," DEPARTMENT ");
uputs(0,0,16, "THANKS TO H.O.D ");
uputs(16,0,16," GUIDE & ALL ");
uputs(0,0,16, " NAME ");
uputs(16,0,16," NAME ");
uputs(0,0,16, "your in setmode ");
uputs(16,0,16," pls select id ");
while(1)
if( ID_SET_KEY == 0)
uputs(0,0,16, " u r in setmode ");
do
select_id_sw();
} while(ID_SET_KEY == 0);
uputs(0,0,16, "VEHICLE ZONE ID ");
TX_PORT = send_id;
  • Attention to detail is absolutely essential to any kind of programming.
    Human readers may give you the benefit of the doubt, but a compiler will not, and neither will a processor.
    This forum gives perfectly clear instructions on how to post source code:
    www.danlhenry.com/.../keil_code.png
    You need to learn to look for details like that, and pay attention to them!
    Note that TABs don't work (well) - use spaces instead,
    and don't forget to check it in the 'Preview'...
  • "i have the C program for it, but i need Timer.h & Lcd.h for it to work...."
    You need the headers to make it Compile - but the headers alone will not make it work.
    To make it work you will also need the corresponding source and/or library files.
    It is impossible to supply headers without knowing what the corresponding sources and/or libraries are!
    And, if you do already have the source and/or library files, you must surely also have the headers?!
  • i got thz code frm my senior and it works fine in the kit.. they lost the header files and i hav all other codes except the mentioned timer and lcd library files... i just want to edit & put them in the AT89C52
    #include <stdio.h>
    #include <lcd.h>
    #include <timer.h>
    PORT: TX_PORT   = P2;
    PIN: IN_A0      = P3.3;
    PIN: IN_A1      = P3.4;
    select_id_sw()
               send_id = 0;
              send_id = 1;
               send_id = 2;
              send_id = 3;
    main()
     unsigned int d;
      while(1)
             do
                select_id_sw();
             TX_PORT = send_id;
  • PORT: TX_PORT   = P2;
    PIN: IN_A0      = P3.3;
    PIN: IN_A1      = P3.4;
    This is not Keil syntax - so you must be in the wrong forum!
    Even in the right forum, nobody can give you the headers without knowing what the corresponding sources and/or libraries are - and if you have those, you can easily recreate the headers yourself!
