Dear all, I am using LPC 2132 controller. In nested interrupt IENABLE and IDISABLE macros giving error in RVCT. The error is as below
source\cpu.c(61): error: #20: identifier "LR" is undefined source\cpu.c(61): error: #20: identifier "SP" is undefined source\cpu.c(61): error: #20: identifier "LR" is undefined source\cpu.c(61): warning: #1287-D: LDM/STM instruction may be expanded source\cpu.c(61): error: #20: identifier "SP" is undefined source\cpu.c(61): error: #20: identifier "LR" is undefined source\cpu.c(61): error: #29: expected an expression
Can any body suggest the problem in my project settings. The same function and same macro is working in CARM. Regards S Rajan
You can't use those macros in RVCT.
Then how can i use nested interrupt in RVCT. S Rajan
You have to write it in an assembly module
See: http://www.keil.com/support/docs/3229.htm
