User defined memory space (mspace)
Former Member
Former Member
Hello all.
I'm using 0x80000(, 0x90000..) as a mspace for external eeprom(s). Is there a way to avoid to check the (valid) mspace of constants?
Or even better, to add a 'new' memory space?
#define T_SIZE    16
#define P_SIZE    4*T_SIZE
#define Params_E      (0x080000 | 0x0140)
#define ParamTab_E(n) (Params_E+n*T_SIZE)
#define Param_Chk_E   (Params_E+P_SIZE)
unsigned char * pp;
unsigned char tmp = 0;
// This doesn't work
pp = (unsigned char *)0x80050;
// This does work
pp = (unsigned char *)(0x80000 | tmp);
pp = (unsigned char *)Params_E;
pp = (unsigned char *)ParamTab_E(0);
// This does work
pp = (unsigned char *)ParamTab_E(tmp);
pp = (unsigned char *)Param_Chk_E;
  • I'd suggest reading the compiler manual sections on "far" pointers and pointer types.
    Non-far pointers in Keil C are only 16 bits wide. You can't stuff an address like 0x80000 in them. That would require an "unsigned char far *".
    You'll also be interested in the contents of absacc.h, including the FVAR / FCVAR macros. These macros take care of the conversion for the memory type byte in the "generic" pointer.
  • Former Member
    0 Former Member in reply to Drew Davis
    Thanks Drew,
    That's just what I have been searching for.
    I'll have to write an ASM-driver and voila.
    I have used something like this to avoid the error message:
    unsigned int  temp;
    unsigned int  * anypointer;
    temp = 0x1234;     // some address in eeprom
    anypointer = 0x80000 | temp;
    if ( (*(char *)anypointer) == 8 )
        .. // special routine for eeprom
    else
        .. // ordinary memory handling
  • Look in your Keil\C51\Examples folder for examples of accessing EEPROM like this.
    I think the driver or compiler handles the decision on which memory handling to use - I don't think it needs to go in your application software?
