Lookup table in C
To make a lookup table in c,I've tried like this
static code unsigned char T[]={0X01,0X02,0X03};
.But is it possible to prepare one as we do in assembly.
org 3000h
db 01h,02h,03h
i.e assigning some address to the variable T in the example given above.
Thanks,
Lina
  • "i.e assigning some address to the variable"
    No, it isn't.
    You can fix the address (see the _at_ keyword in the Manual), or you can have initialisation - but not both!
    If you really need to fix the location of the table, you must either do it in assembler, or use Linker controls.
    It's beed discussed ad nauseam - just try a search for "_at_"
  • But is it possible to prepare one as we do in assembly.
    org 3000h
    db 01h,02h,03h
    Absolutely
    .h for C modules
    code unsigned char T[];
    .a51
    PUBLIC T
    org 3000h
    T: db 01h,02h,03h
