the keil can detect the interrupt ,but can't run into the interrupt function ! thank you ! //my program ! use DS89C420 MICRO CHIP! #include "reg420.h" unsigned int count; void ini_INT12(void); main() { ini_INT12(); while(1); } void ini_INT12(void) { EX2 =1 ; EA = 1; } void INT12(void) interrupt 12 using 2 { P3 = 0; //can't run to here ! } thank you !
Are you sure that the correct interrupt number is 12? Stefan
to Stefan : yes i can make sure ! because the keil set the interrupt flag EX3 to 1 . dear stefan ! you help me a lot . thank you ! i am a freshman about keil c!
I am not familiar with your particular device, but I think you are confusing the interrupt enable bits with the interrupt flags. You also seem to be confusing external interrupts 2 and 3. I still think you are specifying the wrong interrupt number for your interrupt service routine. I suggest you look at the Keil manuals and the datasheet for your device. Stefan
thank you all way ! I am not confusing external interrupts 2 and 3 and not confusing interrupts enable and interrupts flags ! I type the EX2 for wrong! good days! i think you are an expert about keil c!
Jeny, if you still need know why, here you go: "... - the keil can detect the interrupt, but can't run into the interrupt function ! - Are you sure that the correct interrupt number is 12? - yes i can make sure ! because the keil set the interrupt flag EX3 to 1. - I think you are confusing the interrupt enable bits with the interrupt flags. You also seem to be confusing external interrupts 2 and 3. I still think you are specifying the wrong interrupt number for your interrupt service routine. I suggest you look at the Keil manuals and the datasheet for your device..." 1. EX2 (or EX3, if you like) is not any interrupt flag but the interrupt enable bit! It was set by your program statement "EX2 = 1;", not by keil (debugger intervention)! IE2 (or IE3) in SFR EXIF (not bitaddressable register) is the correspondent interrupt flag. IE2 flag is set by processor (and keil debugger) when the following interrupt condition occurs: P1.4: 0->1 transition (for IE3 - P1.5: 1->0 transition) and must be cleared by software. 2. As you know, when an interrupt is detected the processor control is directed at the correspondent fixed address (even if there is no service routine placed there!) in order the request to be serviced. For the external interrupts 2 and 3 these address vectors are 0x43(=67) and 0x4B(=75), respectively. Particular interrupts are assigned numbers according their addr. vectors in ascending order. Interrupt vectors make series: 0x03(=3), 0x0B(=11), 0x13(=19), 0x1B(=27), and so on. That's why the relation between interrupt vector and interrupt number is: Int_vector = 3 + 8 * Int_number or Int_number = (Int_vector - 3) / 8 Therefore the interrupt number for the external interrupt 2 is: (67 - 3)/8 = 8 (for ext int.3 it is 9) and not 12! (Datasheet says 12 is the Watchdog interrupt number) So, I am sorry Jeny, but Stefan is definitely right. You can try the fixed program below: a) build the project b) run debugger c) open peripheral windows: I/O-Ports: Port1, Port2 and Port3 (Interrupt System, select P1.4/Int2 or P1.5/Int3 sources) - not necessary d) run program (F5) e) clear and set repeatedly Port1 pins 4 and 5 P1.4 0->1 transition will clear Port2 and set Port3 P1.5 1->0 transition will clear Port3 and set Port2 Good luck!
#include "reg420.h" void ini_INT(void); void main(void) { ini_INT(); while(1); } void ini_INT(void) { EX2 = 1; // enable ext. interrupt 2: POSITIVE edge on P1.4 EX3 = 1; // enable ext. interrupt 3: NEGATIVE edge on P1.5 EA = 1; } void INT8_EX2(void) interrupt 8 { P2 = 0; // you can certainly get here ! P3 = 0xFF; EXIF &= ~0x10; // clear external interrupt 2 request flag } void INT9_EX3(void) interrupt 9 { P3 = 0; // and here, too ! P2 = 0xFF; EXIF &= ~0x20; // clear external interrupt 3 request flag }
