Greetings,
I may have an old version of the distribution files and if that is the case, please ignore this.
If your use the STM32_Init.c file, this may be of interest to you.
For the Keil MCBSTM32 examples, all the STM32_Init.c files that I have looked at have a bug in the timer initialization. If you set the configuration wizard to enable details for any timer except for timer 4, you will not get expected results. In the conditional statement that happens if timer details is selected the TIMx->PSC and TIMx->ARR (where x=1->3) are not assigned the proper values. They all get the values from the timer 4 setup.
I have verified that other colleges here have the same situation and just wanted to give people a heads up.
Hello Leon Montgolf,
which version are you using?
Best Regards, Martin Guenther
I ran into the issue and did not know if it had been fixed. After the post I found out I had an older version and a newer one was available.
The real purpose of the posting was to warn others that the issue did exist, I ran into it, and it may be applicable to you. In other words, "this smacked me between the eyes; look out so it doesn't happen to you". ;-)
