Processor: STM32F103RB (Kiel evaluation board MCBSTM32)
I am attempting to setup a timer triggered ADC operation. To trigger the ADC I was planning to use TIM1_CH1.
I am having problems understanding the timer section. There are just so many permutations I am becoming confused as to what the minimum is I need to do.
I looked at the timer example. In the configuration wizard I see it setup with timer 1 enabled, I see the time period setup and set for an interrupt. I assume I do not need the interrupt and the signal is just utilized internally.
In looking at the GP timer block diagram, it seems to indicate that I must do something with the “capture/compare channel†to get the signal to trigger the ADC. Here things get pretty deep for me.
Can anyone help simplify this a bit?
sorry canny help ya
