I am busy on a new project with a STM32F207. On our last projects we used STM32F10x-Devices and for debugging purposes I used the corresponding debug.ini file.
/******************************************************************************/ /* Dbg_STM32F2xx.ini: STM32F2xx Debugger Initialization File */ /******************************************************************************/ /* This file is part of the uVision/ARM development tools. */ /* Copyright (c) 2005-2013 Keil Software. All rights reserved. */ /* This software may only be used under the terms of a valid, current, */ /* end user licence from KEIL for a compatible version of KEIL software */ /* development tools. Nothing else gives you the right to use this software. */ /******************************************************************************/ _WDWORD(0xE0042004, 0x00000027); // Set DBGMCU_CR
The old ini file was much more verbose and meaningful. And the content of the DBGMCU_CR register is not compatible between F1 and F2 devices.
Do I have to setup the freeze registers BGMCU_APB1_FZ and DBGMCU_APB2_FZ)? Can this be done here in the ini file?
Is there any example ini file available where I can choose the peripherals (timer, can, etc.) which should stop when core is halted?
Thank you Leo
