problem with qsort
When I use the C++ function qsort, it hangs when the data contains duplicated values.
Here is an example
unsigned char Array[] = {0,5,7,1,3,9,5};
int BCompare(const void* a, const void* b)
    return(*(u8*)a - *(u8*)b);
void main(void) {
        int i;
        printf("\n\rBefore Sort");
        for (i=0;i<7;i++) printf("%d,",Array[i]);
        qsort(Array, 7, sizeof(u8), BCompare);
        printf("\n\rAfter Sort");
With Array containing unique numbers, the sortfunction is OK
Any idea ?
Kind regards
Luc Vercruysse
Tool Version Numbers:
Toolchain: RealView MDK-ARM Version: 3.15b
Toolchain Path: BIN31\
C Compiler: Armcc.Exe V3.1.0.914
Assembler: Armasm.Exe V3.1.0.914
Linker/Locator: ArmLink.Exe V3.1.0.914
Librarian: ArmAr.Exe V3.1.0.914
Hex Converter: FromElf.Exe V3.1.0.914
CPU DLL: SARM.DLL V3.15b
Dialog DLL: DARMST9.DLL V1.03
Target DLL: BIN\UL2ARM.DLL V1.32
Dialog DLL: TARMST9.DLL V1.01a
