Step Into doesn't work in our own AGDI DLL for our own MCU with 22-bit contiguous mode compatible to DS80C390.
StepInto works as Step Over does and AG_GoStep(...) get the same nCode in AGDI DLL when we push F11 or F10 in disassembly window disable.
the following is a demo.when lcall executes,F11 is no use.but start label located at 100h ,for example,F11 works. why? ;----------------------------------------; ;$MOD_CONT ?PR?MAIN SEGMENT ECODE RSEG ?PR?MAIN ORG 0000h LJMP MAIN ORG 600H start: NOP LedTwinkle: ret NOP ; ORG 0ffH MAIN: lcall LedTwinkle jmp main END
