Can the preprossesor compute my const table?
I want to protect the uC from having time intensitive computation while runtime. So i use some predefined const tables. As uC has only 8 kbyte RAM but 62 kbyte Programm_memory i have to chose Programm_memory.
I normaly write a old-fashioned Q-BASIC programm, which computes my table, converts numbers to hex and writes the whole stuff in a text-file like this one:
const unsigned short int my_weird_table[16384] =
0x07E9,0x07D4,0x078F,0x0774,0x0780,0x0788,0x0785,0x0785,
0x0786,0x0785,0x078C,0x0792,0x0797,0x07A2,0x07AC,0x07B2,
0x07BA,0x07C0,0x07C6,0x07CD,0x07D2,0x07D2,0x07CF,0x07B9,
0x078D,0x0764,0x0755,0x0767,0x078A,0x07AC,0x07CA,0x07E4,
0x07F3,0x07F2,0x07E7,0x07DC,0x07DA,0x07E2,0x07E9,0x07E4,
0x07D5,0x07C1,0x07AE,0x0798,0x0778,0x0751,0x0728,0x06FC,
0x06D2,0x06B1,0x069F,0x069F,0x06AC,0x06B4,0x06AB,0x0697,
0x068A,0x0691,0x06AB,0x06C7,0x06E6,0x0707,0x0719,0x0712,
0x06F6,0x06D1,0x06B3,0x0697,0x0662,0x0614,0x05DB,0x05C6,
0x05C0,0x05DE,0x0642,0x06DA,0x0769,0x07BD,0x07CB,0x079E,
0x07FE,0x0800,0x0802,0x0805,0x0807,0x0804,0x0803,0x0802,
0x0801,0x0801,0x0801,0x0800,0x0800,0x0800,0x0800,0x0800,
0xFFFF};
don't want to bore you, the computation part of my Q_Basic-programm can look like:
    If (X < (2 * PI) then
        Y = 1.5 * sin(X) + .75 * sin(2*X) + .05 * sin(5*X)
    else
        Y = sin(3*X)
    end if
    table(N) = 32768 * (1 + .5 * Y)
Now my idea: Isn't that a job, the preprossesor can do for me? I'am not sure about syntax, so i expect your suggestions very excited ;-)
  • No, the prreprocessor is intended to make decisions, not to make computations.
    You will have to continue to create your tables with an external program.
    On the other hand, you can modify your project to run the external program before a rebuild.
  • On the other hand, you can modify your project to run the external program before a rebuild.
    how can this be done?
    Are there no other alternatives?
    A kind of macro?
  • No. No macro. A preprocessor can not produce any real work. It can only cut and paste and decide. It is not a programming language. It is a form of decision-making language.
    Open your project options. Scan the pages from left to right. Suddenly, you will find a page where you may enter the name of commands to run before or after a project build or C/C++ file compilation.
    On the other hand - if your tables changes very seldom, it is better to manually run your support program to build the relevant table(s).
