Flash: /BHE active while /RD is active and /WR inactive - is it OK?
Hello!
The board is built on C167CS crystal, with external RAM and flash at two separate (with individual /CS) 16-bit non-multiplexed buses. The flash is split into two 8-bit-data chips, the WRCFG is set to have normal configuration of /WR and /BHE. For the flash, MCU's address line A0 and the line /BHE are used along with single /CS for both flash chips to get access to the lower and upper bytes of flash. The (same) MCU's /WR and /RD pins are mapped both to the RAM and flash (and other periphery).
The f/w executes from the external flash (i.e. there are /RDs for the flash), and performs read/write operations to the RAM. No any write operation is being done to the flash (the f/w at this point does not re-program the flash) - i.e., if MCU's /WR is active, the flash's /CS is inactive. Using scope I see the /BHE becomes active (i.e. low) when flash's /CS is active, and /RD is active.
From the C167 manual it is not quite clear whether /BHE works with /WR signal only or with both /RD and /WR signal.
The f/w runs OK, but I need to get a confidence if my inderstanding is correct: can the /BHE be active in described situation where only /RD is performed, i.e. should /BHE be active not only for the /WR?
Thanks,
Nikolay.
  • Here is an excerpt from the manual which, I think, suggests that BHE is used during reads too:
    When reading bytes from an external 16-bit device, whole words may be read and the C167CS automatically selects the byte to be input and discards the other. However, care must be taken when reading devices that change state when being read, like FIFOs, interrupt status registers, etc. In this case individual bytes should be selected using BHE and A0.
    Basically, it says that in most designs you can ignore BHE during reads, but in some designs (when interfacing some FIFOs, for example) you cannot ignore it.
  • Thank you,
    This is valid point. Unfortunately, neither in Infineon nor in ST docs there is no explicit wording or (better) timing diagram reflecting how the MCU operates with the /BHE.
    Before questioning, I have had look at Hitex's Insiders' Guide (the link is www.hitex.com/.../166des19-a.html), however have not found explicit mentioning on /BHE pin functionality either. But here is an useful info, page 29. Hitex authors talk about a RAM, but it does not matter for the case:
    To successfully use 8-bit RAMs the user must remember that the A0 pins on the RAMs go to A1 on the 167. ... A0 is effectively redundant in such a configuration. ... When the CPU reads a word both RAMs are enabled simultaneously by /READ so that the CPU can read D0-D15 in one access across the bus. As the 166 is a 16-bit machine, all read accesses are wordwide, even byte ones - the unwanted byte is simply discarded.
    For writes to RAM some means of only enabling one of the RAMs is required, as a byte write to an even location would corrupt the associated odd byte. The traditional method of preventing this is to create individual /WRITE signals for each RAM from /BHE and A0. ...
    Here again, most accent is given to the /WR operation, with /BHE not mentioned for the reads. As a summary, it is more or less evident that the /BHE is redundant for most /RDs configuration (except that one you pointed out), however is generated by MCU for both /RD and /WR which is seen in real h/w when a scope is hooked-up.
    P.S. The only explicit diagram I finally found today is in the "C167CS Data Sheet V2.2" (not User Manual), pages 66-67, 69 where the /BHE is very schematically shown on timing diagram together with address lines A0...A23, for both write and read (!) accesses.
    Regards,
    Nikolay.
