I use the RENAMECLASS-command to define a BOOT_CODE-class.
When I create the following classes:
ICODE (0xC00200-0xC002ff), BOOT_CODE (0xC00300-0xC017FF)..
..and I force the linker to set the startup-code to:
SECTIONS (?C_STARTUP_CODE%ICODE (0xC0200))
.. I have the following result:
0C0200H 0C0359H 00015AH CODE REL WORD --- --- PRIV ICODE ?C_STARTUP_CODE .. C00300H C005B9H 0002BAH CODE REL WORD --- 1 PUBL BOOT_C ?PR?OSYS -ODE
The means the code in startup is overlapping with the code of BOOT_CODE-class.
I am confused, because I do not get any linker warning..
Thanks for the help! Best regards, Josef
Maybe I am missing it but you don't have overlapping memories.
You have two unique segments...
0x0Cxxxx and 0xC0xxxx
Ups, this was a PICNIC-problem (Problem In Chair, Not In Computer).
A zero for the ICODE-section was forgotten during mapping-configuration.. shame on me.
Thanks a lot!
Best regards, Josef
