Hi All: I was using uVision 3 with the RealView 3 'C' compiler without problem for a while... Suddenly, I got an error from the compiler:
** Segmentation fault
and I got an unhandled win32 exception from the armcc.exe program.
I desintalled and re-installed the programs again, but the error still there... It would be a hardware memory error?
Thanks; Gus
Which MDK version are you using (uVision-Help-About) ? Could you provide an example on how get this fault ?
You might try going back to a prior, known good (i.e., builds without errors or warnings) version of your source code and trying again. If the problem does not go away, that would seem to point to a problem with the tools. However, if the problem goes away, then you can try putting the changes back, one piece at a time till the problem shows up again. Then you can try to figure out if the fault lies with your code or the tools. If you're sure it's the tools, contact KEIL tech support, and provide them a test case to show the problem you're having. They're pretty good at responding to tech support requests. Giving them a (small as possible) test case makes it much, much easier for them to figure out what's wrong.
Having the same type of problem: when I attempt to access an LPC-based project in uVision 3, armcc.exe throws an access violation at address 0x001082D0. I have submitted a support request, hours ago, so I don't expect a reply yet.
Trying to talk through a uLink2 emulator to a MCB2368 eval board, from a Win XP Pro SP2 system.
I've tried rerunning the install, in case armcc.exe was damaged;
then I uninstalled and reinstalled from scratch;
last I tried uninstalling, deleting the C:\Keil tree, scrubing the registry for 'uVision' 'Keil' 'armcc', _then_ reinstalling, and even after that, I get the same access violation.
Waiting for a tech suport opinion now.
Hi Howard: I'm using version uVision3 v3.51 . The Armcc.exe does not provide any version number. The assembler is RVCT 3.0 (build 951). The problem is not with a particular project. With every project (including the ones that becomes as examples with the tool) I get the error. I tried with different hard Disk/Windows in the same machine, the Hard Disk in another machine, and even reinstalled the tool in a different machine... I don't know is happening but in all cases (including in a new machine) I got the same error: "** Segmentation problem" It would be usefull if you share the tech-support response...
Regards; Gus
Brian Clough from Keil TS suggested downloading the most recent MDK, version 3.11. I have done so, installed it clean, and the error is gone. I'm using a MCB2368 eval board, and the Blinky example is running on it now.
It looks to me like the trouble was with just that particular version.
Good luck with that, or what ever other solution you might come across...
Using uVision-Help-About shows the compiler and assembler (plus some more) version numbers, the example here is for MDK3.10:
C Compiler: Armcc.Exe V3.1.0.903 Assembler: Armasm.Exe V3.1.0.903 Linker/Locator: ArmLink.Exe V3.1.0.903
V3.1.0.903 really means: V3.10, Build 903.
You can obtain the version numbers also from the command line in a dos box:
C:\Keil\Arm\Bin31\ArmCC --vsn C:\Keil\Arm\Bin31\ArmAsm --vsn
Assuming you are using your correct path for 'C:\Keil\Arm\Bin31', the results for MDK3.10 will be:
ARM/Thumb RVCT3.1 [Build 903] for uVision [Standard] Software supplied by: ARM Limited ARM/Thumb C/C++ Compiler, RVCT3.1 [Build 903] for uVision [Standard] Software supplied by: ARM Limited
ciao at all
Hi have the same problem of Gustavo Sabina
The problem is very simple On winxpSp2 open dos windows
go to program/keil/ARM/BIN30
and type "armcc" the result is
C:\programmi\Keil\ARM\BIN30>armcc
and the same error message appears on desktop
Solutions ?
ciao, beppe
Hi All: Downloading the last version, the problem is solved.
Thanks for all;
