Hi To All,
Currently I observe very strange situation when I have started to use remapping of exception vectors to RAM after application gets started from internal flash – the load/programmed area (used CPUs :STR710 and STR11):
Application starts running just fine, but …. When the following functions are called
GPIO_BitWrite(GPIO1, 9, 1); // setting the bit 9 of IOPORT1
GPIO_BitWrite(GPIO1, 9, 0); // resetting the same: bit 9 of IOPORT1
… Application stacks and I see exception vector area in RAM - changed
Remark :( Prior calling these both functions the pin is set to output with: GPIO_Config(GPIO1, 0x0200, GPIO_OUT_PP);)
Some more info and details I was able to find so far: 1).The situation does happen if there is a delay between the two calls (called functions without delay one after another does not cause a problem); 2) Both of them have to be called the problem to happen; 3) Not using library functions, but direct access to register instead via pointer, like that: (U16 *) pGPIO1 = (U16 *)(0xE0000000+ 0x4000+ 0x0c); ... Does not help – same result 4) I have tried two tool chains – RV MDK's and Keil's – same result; 5) I have tried two different ways of expectation vectors remapping: - The way described in ST forum with RV MDK's tools;
- Using manual way with Keil's tools, with code like this at the beginning of main():
// remap U32 index; U8* dst = (U8*)0x20000000; // beginning of RAM, 64 bytes reserved via linker setting U8* src = (U8*)0x40000000; // beginning of internal FLASH first 64 bytes are reset vectors U32* pboot = (U32*)0xA0000050; // booting register address
for(index = 0; index < 64; index++) dst[index] = src[index]; // copy vectors to RAM
index = *pboot; index = index & 0xFFFFFFFC; index = index | 0x2; *pboot = index; // set 0x00000000 to RAM
// remap
… and result is the same
Someone has the same situation? Thanks a lot in advance for any help!!
Nivelinn
