Dear All, I am using microvision 2 and c8051F12x. I want to execute a function stored in the code memory using a toolbox button. I have created a toolbox button which loads the PC with the address of the particular function.That is working fine and if I wan to execute the function, I have to press F5 or F10 or F11 until the end of the function. But, is there any way to execute the function in code space by just clicking the toolbox button? Thanks in advance, - Neo
you can assign multiple commands when you separate them by ';'. For example:
>DEFINE BUTTON "run", "$=C:0x100; G"
"I am using ... c8051F12x." Just by the way, note that the toolset for this should be "Cx51 & 8051 Development Tools" - not "C251"
Just by the way, note that the toolset for this should be "Cx51 & 8051 Development Tools" - not "C251" Sorry, it was by accidental Thankyou both! And Keil, I want to know the other available commands similar to "G". Where can I get those command set? Thanks again. - Neo
http://www.keil.com/support/man/docs/uv3/uv3_debug_commands.htm
