ARM7 printf long long int
Hi, my program does not do the expected things, printf a unsigned long long int.
#include <aduc7026.h>
#include"stdio.h"
void RS232_init(void);
int main (void)
	unsigned long long int A;
	RS232_init();
	printf("Start \n");
	while(1)
		while(1)
			printf("Enter a Hex-number\n");
			if (scanf("%X",&A)) break;
			scanf("%*");				//Clearing scanf input stream
		printf ("Your input %64.64lX\n",A);
		A *= A;
		printf ("The result %64.64lX\n",A);
	GP1CON = 0x011;			// Setup tx & rx pins on P1.0 and P1.1
   							// Start setting up UART at 9600bps
   	COMCON0 = 0x080;		// Setting DLAB
   	COMDIV0 = 0x088;		// Setting DIV0 and DIV1 to DL calculated
   	COMDIV1 = 0x000;
   	COMCON0 = 0x007;		// Clearing DLAB
the Output via RS232: Start Enter a Hex-number Your input 0000000000000000000000000000000000000000000000000000000011111111 The result 0000000000000000000000000000000000000000000000000000000087654321 Enter a Hex-number but when stepping through the programm ?C?QMUL?A: 0x00080F78 E08CB290 UMULL R11,R12,R0,R2 0x00080F7C E02CC192 MLA R12,R2,R1,R12 0x00080F80 E021C093 MLA R1,R3,R0,R12 0x00080F84 E1A0000B MOV R0,R11 0x00080F88 E12FFF1E BX R14 after the UMULL the expected result (0x0123456787654321) is in R12/R11 for some just a little moment... Sometimes i think C is the pureness of evil.
  • "Sometimes i think C is the pureness of evil."
    If you deliberately jumped into a deep pool without first taking the precaution of learning to swim, would it be the pool's fault if you drowned??
  • "my program does not do the expected things, printf a unsigned long long int."
    So what do you expect it to do?
    You've told printf to print a long, but you've actually given it something twice the size!!
  • 		printf ("Your input %64.64lX\n",A);
    Does it really surprise you that printf barfs 64 digits at you if you tell it to use a width of 64 digits ?
    Also, 'l' as the length means a long int argument. For a long long int, use 'll'.
  • Hi, my program does not do the expected things,
    Important rule of programming: Programs do what you tell them to do, not what you expect them to do. :)
  • I just want to force printf to give me unsigned long long integer
    for example 0x11111111 * 0x11111111 i expect 0x0123456787654321 but the result from printf is only 000000000087654321.
    What a mess! I'am very very disapointed!
    Maybe the compiler does not recognize "unsigned long long integer"?
    But there's no error-message!
    Who can help?
    Then why are you telling printf that the length is long integer (l) instead of long long integer (ll) ?
  • "Maybe the compiler does not recognize 'unsigned long long integer'?"
    The compiler recognises it, and the compiler has given you one.
    However, you have told printf to print a long, and that's exactly what it has done - it has printed a long which is precisely one half of the long long that you supplied!
    As a programmer with 10 years 8051 assembler experience, you should understand that silly things will happen if you supply inconsistent parameters to a fucntion call!
    "But there's no error-message!"
    That's because the program is perfectly valid.
    That problem is that your program does not actually describe what you want it to do.
    Again, as a programmer with 10 years 8051 assembler experience, you should realise program execution is a YAFIYGI process:
    "You Asked For It; You Got It!"
    You really do need to sit down with a basic 'C' textbook and start with the basics before you go running & jumping into the deep end before you can walk or swim!
  • sorry i told program to multiply 0x11111111 with 0x111111. The result is 0x0123456787654321.
    Then i told the program
    printf ("The result %16.16LlX\n",(unsigned long long)A);
    what i understand should give me a 16-digit-long-long-Hex-number. Have you ever tried to printf long-long? ;-)
  • "what i understand should give me a 16-digit-long-long-Hex-number."
    And what did it give you?
  • printf ("The result %16.16LlX\n",(unsigned long long)A);
    By the way, why are you specifying a precision for an integer number ?
  • The CARM compiler does not support printout of long long int values. You should select the RealView Compiler (under Project - Components...). This compiler supports the ANSI C99 extensions.
    Reinhard
  • It seems that printf can not print unsigned long long integer with more than 8 Hex-digits.
    Here is my workaround for printf unsigned long long as hex.
    #include"stdio.h"
    void printf_ull_hex(char[],unsigned long long,char[]);
    int main (void)
    	unsigned long long A;
    	unsigned char n;
    	RS232_init();
    	printf("Start\n");
    	A=1;
    	for(n=0;n<=40;n++)
    		printf("3^%2.d ",n);
    		printf_ull_hex("= 0x",A,"\n");
    		A *= 3;
    	printf("Stop\n");
    	while(1){}
    void printf_ull_hex(char str1[],unsigned long long ull_num,char str2[])
    	printf (str1);
    	printf ("%8.8X",ull_num>>32);
    	printf ("%8.8X",ull_num);
    	printf (str2);
    Hope it will be helful to other users :-)
  • "It seems that printf can not print unsigned long long integer"
    There is no "seems" about it - you have just been told explicitly by Reinhard Keil himself that The CARM compiler does not support printout of long long int values.
    Further, you have also been told that the RealView Compiler does support this ANSI C99 extension
    It only remains to check the GCC manual to see wether or not GCC supports it.
    (I have a feeling that GCC does support C99...?)
  • "It only remains to check the GCC manual to see wether or not GCC supports it."
    Once you can actually find the manual! :-(
    http://www.keil.com/forum/docs/thread7639.asp
    Here it is:
    http://www.gnu.org/software/libc/manual/html_node/Integer-Conversions.html#Integer-Conversions
    It says that you can us 'L' (uppercase), 'll' (lowercase), or 'q' to qualify a long long int.
    Note that a single lowercase 'l' still indicates a long int
  • Sorry, your' right.
    See me as someone, who is learning to fly C like the man in the film Those Magnificent Men In Their Flying Machines
    While he flying, he reads the book "Learning to fly in five lessons"
    And suddenly the wind brushes the book away...
    But by the way, what is the difference between all this different compilers?
    Isn't the Keil-Compiler the best in the world?
    I can't say, i came to it like the virgin to a child.
    I just bought this ADuC7026-Eval-Kit.
    There was a CD... i installed it... and here we are.
