I2C_BufferSend for 71x?
Hey folks,
Trying to get some older code working with the latest Keil toolchain. I have some I2C code that uses I2C_BufferSend().
The target is an STR712, and uses the 71x stuff in the library.
My problem is that there is NO I2C_BufferSend in the 71x/i2c.h (There is an I2C_ByteSend and I2C_AddressSend in 71x/i2c.h as well as both of those AND the I2C_BufferSend in the 73x/i2c.h.
Is there equivalent functionality using a different call for the 71x target family?
Thanks,
Steve
  • In case anyone google's this and finds the question and no answer (don't you hate that?)
    ST wrote and maintains the STR71x libs. They've actually removed the I2C_BufferSend() between v3.0 and v3.1. (found this in the release notes)
    So, the solution is to build the equivalent functionality with the other I2C utilities.
    Steve
