How to setup the own application using the iap driver from ST-Microelectronics
Has anyone experience using the IAP-driver from ST-Microelectronics. the driver is working correctly but I can't run my own application at address 0x40002000.
Has anyone an exampleproject how to setup the own application. ( I use interrupts and have some parts of program located in ram).
needing help urgently
thanks
Manfred
  • Hello,
    I meet face a difficulty same you.
    My test program without Interrupt was running on IAP.
    However, My application is using Timer Interrupt, So, my application was pause at Timer Interrupt.
    I think that Interrupt Vector is remapped at RAM Aera. But I don't know method.
    Though, My application was modified by ADS(Arm Developer Suite), then it is running on IAP.
    I want to work by Keil Environment. So I want method to work it.
    Please Help me!!!
