putstr()
CAn anyone point out what is the error is following code? It compiles OK, but doesnot work as expected.
code char* str1="xxyyzz";
void putstr(const char *s){
unsigned char ctr=8;
do{
tx_busy=1;
SBUF=*s++;
while(tx_busy);
}while(--ctr);
void main void()
putstr(str1);
'tx_busy' is a flag that is cleared from serial interrupt routine when it gets a tx-interrupt.
My serial port is working OK, if i use it as below, for example.
SBUF='X';
Any help would be appreciated.
Azra
  • but doesnot work as expected.
    What exactly does it do, then ?
    Also, the code sends 8 bytes of a string that only has 6 bytes.
    Have you tried monitoring the TI bit directly ?
