can anyone find this in the ANSI C standard
I am not asking what it will do, that is a simple experimnt that I can do myself. Does anyone have specific knowledge of whether the following for loop where WFLcnt is an unsigned char is specified in the ANSI C standard to run 0 or 256 times.
  for ( WFLcnt = 0 ; WFLcnt !=0 ; WFLcnt++)
YES, if WFLcnt was a short, the question is moot, but i need to use a char for speed reasons. in advance, thanks Erik
  • cond-expression is evaluated before each iteration, while the last statement is evaluated at the end of each iteration.
    The for-loop is equivalent to:
    WFLcnt = 0;
    while(WFLcnt != 0)
     WFLcnt++;
    So it should run 0 times.
  • Sorry about the formatting. Preview looked okay. But post-preview, all the paragraph breaks would get removed. I had a bad feeling it would come out like that, despite the preview, but I posted anyway.
  • You Could try a post on the comp.lang.c newsgroup.
    "unsigned char" I assume
  • I do it the other way:
      WFLcnt = 0;
      do {
      }while (--WFLcnt);
    When WFLcnt is unsigned char, it will repeat 256 times and the loop counter will be decremented by DJNZ.
  • "I am not asking what it will do, that is a simple experimnt that I can do myself. Does anyone have specific knowledge of whether the following for loop where WFLcnt is an unsigned char is specified in the ANSI C standard to run 0 or 256 times."
    The simple answer to your question is that the ANSI standard guarantees that the loop will run zero times. Whether you use an unsigned char or a short is irrelevant.
    I'd advise you to get hold of a decent 'C' book before going any further. If you don't get a good grasp on the basics of 'C' early on you'll run in to all sorts of unexpected traps.
  • Note that the ANSI standard does not specify that a char shall be 8 bits!
    The ANSI standard requires that a char have at least 8 bits, and that the limits.h file provided by the implementation shalll define CHAR_MAX accordingly.
  • I'd advise you to get hold of a decent 'C' book before going any further. If you don't get a good grasp on the basics of 'C' early on you'll run in to all sorts of unexpected traps.
    Thanks, I have one and have coded C for 15+ years. I just could not find any statement in the standard for "overflow behaviousr"
  • "I have one and have coded C for 15+ years."
    Without understanding how a for statement works?
    "I just could not find any statement in the standard for "overflow behaviousr""
    There is no overflow in your example.
  • sure there is if the condition goes from ff to 0
    if you tried to answer my question instead of trying to find fault with my example, maybe there could come something out of it. yes, the "example" faulty,
    extraction error, extracted from
    ,,,[0] = ...
    for ( WFLcnt = 1 ; WFLcnt !=0 ; WFLcnt++)
       ..... [WFLcnt] =
    but what the.... is wrong with the question. "what does the standard say about overflowing variables". I have used the above extensively, just got to doubt it's "validity" Erik
  • "if you tried to answer my question instead of trying to find fault with my example, maybe there could come something out of it."
    Here's your original question:
    "Does anyone have specific knowledge of whether the following for loop where WFLcnt is an unsigned char is specified in the ANSI C standard to run 0 or 256 times.
    Here's my original answer:
    "The simple answer to your question is that the ANSI standard guarantees that the loop will run zero times. Whether you use an unsigned char or a short is irrelevant."
    In what way does that not answer the question you asked?
    "but what the.... is wrong with the question. "what does the standard say about overflowing variables"."
    That's a completely different question. There was no mention of overflow in either your original question or the example you gave. How can I answer a question you didn't ask?
    The answer to your second, completely different question is that for unsigned integer types the standard guarantees that the increment will wrap from the largest representable value to the smallest. For signed integer types the behaviour is undefined.
