Writing to eeprom
Hi all,
Hope someone can explain what I am doing wrong. I have the following problem.
I am using a AT89C51ED2 micro and running PK51 8.01.
I want to write a variable to and read a variable from eeprom.
I have done a search on the Keil web site and have gained some
advance, but, I can read data from eeprom (V:0x00 - V:????).
When I write to eeprom I see it going into xdata and not the eeprom (v-data).
Is this correct?
Also the EEBUSY flag is never set (EECON bit '0')
Maybe (hopefully) I'm doing something wrong somewhere and someone will spot it.
Below I include my test program.
#include <at89c51xd2.h>
#include <absacc.h>
void WriteEEPROM (unsigned int adr, unsigned char val) small
	  EA = 0;
	  EECON = 0x02;        						// enable EEPROM and set write bit
	  XBYTE[adr] = val;
	  while(EECON & 0x01)						// wait untill programmed
	  EECON = 0x00;        						//  disable EEPROM
	  EA = 1;
unsigned char Read_EEPROM (unsigned char adr) small
	unsigned char v;
	EA = 0;
	v = XBYTE[adr];
	EA = 1;
	return (v);
unsigned char v;
unsigned char f;
void main (void)
	while (1)
		v = Read_EEPROM(0x00);
		f = v*2;
	  	WriteEEPROM (0x10, f);         // write 9 to EEPROM address 0x001
I am only using Dscope, so I can't comment on it working or not working on a live system.
Thanks in advance for any responses
Kind regards
John Garrelts
