Hello all, I am using GPT3 for timing purposes in my RTOS (I am not running it on hardware yet - just in the IDE). I tried to use the example supplied in the "Getting started and creating applications" document (page 163) which is supposed to induce a 1000Hz frequency, but it counts too fast! the following code snippet displays "41" when actually 30 seconds have elapsed. Can it be related to the platform (the fact that I am not running it on the target yet)? here is the code: #include <reg167.h> #include <intrins.h> #include <stdio.h> static unsigned long volatile timer_tick = 0UL; static int sec = 0 ; static void timer3_irq (void) interrupt T3INT = 35 { timer_tick++; if (timer_tick % 1000 == 0) { printf("time sec=%d\n", sec) ; sec++ ; timer_tick = 0 ; } } void timer3_setup (unsigned int ticks_per_sec) { unsigned int reload; unsigned long frequency = 2500000; unsigned int prescale; for (prescale = 0; prescale < 8; prescale++) { if ((frequency / ticks_per_sec) <= 65535) break; frequency /= 2; } reload = frequency / ticks_per_sec; T3CON = 0x0080; /* 2.5MHz, Timer Mode, Count Down */ T3CON |= prescale; T2CON = 0x0027; /* Setup T2 for reload operation on any T3OTL */ T2 = reload; /* Reload for T3 */ T3 = reload; /* Start T3 with proper reload */ T3IC = 0x0044; /* Timer 3 interrupt enabled, Level 1 */ T3R = 1; /* Start Timer */ IEN = 1; /* Enable Interrupts */ } void timer3_delay (unsigned long ticks) { unsigned long start_tick; unsigned long timer_tick_copy; _atomic_ (0); /* start un-interruptable code */ start_tick = timer_tick_copy; _endatomic_ (); /* end un-interruptable code */ while (1) { _atomic_ (0); /* start un-interruptable code */ timer_tick_copy = timer_tick; _endatomic_ (); /* end un-interruptable code */ if ((timer_tick_copy - start_tick) > ticks) break; } } void main (void) { /**** Setup serial port function for Uart usage ****/ P3 |= 0x0400; /* SET PORT 3.10 OUTPUT LATCH (TXD) */ DP3 |= 0x0400; /* SET PORT 3.10 DIRECTION CONTROL (TXD OUTPUT) */ DP3 &= 0xF7FF; /* RESET PORT 3.11 DIRECTION CONTROL (RXD INPUT) */ S0TIC = 0x80; /* SET TRANSMIT INTERRUPT FLAG */ S0RIC = 0x00; /* DELETE RECEIVE INTERRUPT FLAG */ S0BG = 0x20; /* SET BAUDRATE TO 19200 BAUD */ S0CON = 0x8011; /* SET SERIAL MODE */ DP7 = 0x01; /* Setup P7.0 for output */ ODP7 = 0x01; /* Setup P7.0 for open-drain */ timer3_setup (1000); /* Setup timer for 1000Hz operation */ while (1) { timer3_delay (100); /* Wait 0.10 seconds */ P7 |= 0x01; /* Turn on P7.0 */ timer3_delay (100); /* Wait 0.10 seconds */ P7 &= ~0x01; /* Turn off P7.0 */ } } Thanks in advance, Tamir Michael
Ok you didn't say if you are using a C166 or XC166? I believe the example assumes a 20MHz CPU Clock. So for the XC16x device assuming an 8MHz external crystal you should have something like PLLCON = 0x6E05 (will get you a 20MHz CPU frequency). For C166 look at the configuration settings under the debug tab along with the crystal frequency you have chosen.
