Hello, I'm programming a OS for C167 and my problem is that the C167 does write with putchar, but when I want to write with printf it only prints the first character of the string. For example:
void initSerial(void) { P3 |= 0x0400; DP3 |= 0x0400; DP3 &= 0xF7FF; S0TIC = 0x80; S0RIC = 0x00; S0BG = 0x40; S0CON = 0x8011; } void main (void) { int i; initSerial(); while(1) { for(i = 0; i < 20; i++) { putchar('c'); } for(i = 0; i < 20; i++) { printf("s"); } } }
This is typically a problem of the memory configuration. printf requires USERSTACK whereas putchar does not need any USERSTACK. Make sure that the user stack is located to a valid RAM space in your hardware. Reinhard
