Hello, I'm using a C167 Bord with uVision2. My program sets the configurations for the serial port,sends some data via the port and it works in the Serial Window #1 (I see the data which I had sent). In the next step I wanted to display some values in the HYPER TERMINAL but nothing happens in the Terminal and I don't know why. thx for your help.
Hyperterminal is very sensitive regarding the correct baudrate. You need really to have a correct baudrate selected. Reinhard
The Baudrate settings are Ok .That is not the problem..thx
Tell us more about your configuration: Do you use the monitor? Do you have a 2nd UART on your C167 board? Did you really init the serial port of the C167? Try a (much) better terminal program like Docklight.
this is a simple program for the serial interface. If I simulate the programm I see "Hallo" in the Serial Window #1. In the next step I flashed the program on the chip and I wanted to see "hallo" in a Terminal Program (docklight) but it doesn't work... #include <REG167.H> #include <stdio.h> void main () { /* 9600 Bd, 8 Datenbit, no Parity-Bit, one Stopp-Bit */ DP3 |= 0x0400; DP3 &= 0xF7FF; S0TIC = 0x80; S0RIC = 0x00; S0BG = 0x40; S0CON = 0x8011; printf("hallo"); while (1); }
Still baudrate depends on XTAL and PLL setup. Also there could be a hardware error. Did you check the COM data lines? Reinhard
Did you check, that your program runs by an other method (for example: toggle a pin)?
how could I check the data lines ? and yes my program runs with a other application.
Check the tx-pin of your C167 with an oscilloscope. If it is toggeling then check the tx line after the RS232 transceiver (for example MAX232). I wanted to know if you have already succesful loaded an other program (wich only toggels one pin) to the FlashROM. I'm a bit confused about "my program runs with an other application".
Just one more late suggestion. You said that that your program displayed Hallo in the simulator serial window. We would suggest that you use the Mode and Assign commands in the simulator and connect the serial window to a com port on your PC. You can then display you simulator I/O via Hyperterminal. This will isolate software/hardware bugs. Like the other replies, we feel you have a hardware bug. Bradford
thx. but the problem is I'm measuring some values and I want to send the results to Visual C++ or to a Terminal via RS232. I can read and display the results in the Serial Window#1 but I do not know how to send the values to the terminal program or to Visual C++..
