XDATA structure with include file compiling problem
In this systemGlobals.c file I declare:
struct SMBusADCEntry_entry
unsigned short int SMBusADCBankNumber;
unsigned short int SMBusADCBankChannel;
xdata struct SMBusADCEntry_entry SMBusADC[] = {
{ (unsigned short int)0, (unsigned short int)0 },
{ (unsigned short int)0, (unsigned short int)1 }
Then in the systemGlobals.h file:
#ifndef __SYSTEM_GLOBALS_H__
#define __SYSTEM_GLOBALS_H__
extern struct SMBusADCEntry_entry SMBusADC[];
#endif
Then I include this systemGlobals.h file in my main.c file and access the data as
SMBusADC[0].channelLowerLimit_UI = 0x20;
The compiler complains on the xdata struct line with duplicate definition.
Additionally then with the above setting of data 0x20 the error SMBusADC undeclared identifier.
