Can I expand additional code & data memory for P89LPC932 ?
In micro-Vision IDE attached to LPC900 Development Studio, the Device/Target menu shows the possibility of expanding off-chip code memory(EPROM) & off-chip Xdata memory(RAM). How to realize it? Does P89LPC932 provide /EA, /PSEN, ALE pins as conventional 8051 ?
  • uVision has facilities to support just about evey 8051-derivative that there is, ever has been, and ever will be. Therefore, inveitably, not all options available in uVision will be applicable to all chips.
    "Does P89LPC932 provide /EA, /PSEN, ALE pins as conventional 8051?"
    A simple glance at the Datasheet will tell you that!
    You're going to have to look at the Datasheet sooner or later, so now would be a good time to start!
  • You're going to have to look at the Datasheet
    Andy:
    You are so far behind the times, nobody in his right mind does that any more.
