help #include
a.h:
struct A {
   int a;
b.h:
struct B {
   struct A ba;
c.c:
#include "a.h"
#include "b.h"
</prev>
compiler complains struct A in file b.h is undefined.  I would think that by include a.h before b.h in c.c, it would see the struct A definition?
I know I could make it compile by adding:
struct A; in b.h but just want to know why it doesn't work the way above.
Thanks,
Anh
  • Your b.h is buggy. A header using data types defined in another one
    has to include that other header, i.e. b.h should read:
    #ifndef MY_B_H
    #define MY_B_H
    #include "a.h"
    struct B {
      struct A ab;
    #endif /* MY_B_H */
    (The #ifndef/#define stuff is standard practice to make headers safe for multiple inclusion.)
    As to the compiler error you got: that shouldn't happen unless you tried to compile b.h on its
    own --- e.g. by adding it to your uVision project as a source file to be compiled,
    which you really shouldn't do.
  • "A header using data types defined in another one has to include that other header"
    But in the example he posted, Anh had included both the headers:
    c.c:
    #include "a.h"
    #include "b.h"
    So, although what you say may be good practice in general, the code as posted should've been OK?
    "unless you tried to compile b.h on its own --- e.g. by adding it to your uVision project as a source file to be compiled -- which you really shouldn't do."
    Quite so.
  • Well, I just tried
    #include <stdio.h>
    #include "a.h"
    #include "b.h"
    void main( void )
    	printf( "Hello, world!\n" );
    and it compiled without error!
  • But in the example he posted, Anh had included both the headers:
    ... in the .c file. That's not solving the problem, it's just avoiding the symptoms. File b.h, as-is, is incomplete. You can't just put
    #include "b.h"
    in any given C source file --- you have to remember to
    #include "a.h"
    first. That's a deficiency of b.h. It may not seem too bad in this simple case, but it'll bite back as soon as you try that same tactics in larger projects.
  • Thanks guys,
    I think I forgot to save the changes to "a.h". It works now.... "a.h" contains a lot of things including one struct needed for "b.h". I am more inclined to include headers from other development groups in .c rather than .h (person reasons).
    Anh
