Simulation problem, DS80C400
I was readed "UVISION DEBUGGER: DALLAS 400 SIMULATION",
which says that DS80c400 cannot be simulated because libraries arent
included in simulator.
That's understood. But, program that I try to simulate does not call
to any address in range C:0x001986 to C:0x001B91 !!!
(that is analyzed by stepping trough disassembly window).
Target is configured for; 16MB contiguous mode;
In startup400.a51 programmed bits are for: Extented stack enabled, and 16MB contiguous mode.
Also, interesting is that program is simulated right when classical stack is used
(in startup400.a51 I use:
"orl acon, #0x00",
"mov sp,#80" )
So, conclusion may be that stack isn't simulated in right way, am I right ?
Thanks for reading, hope someone can reply with some conclusion about it...
BTW, to Keil developers:
I have programmed AGSI-DLL's to simulate lots HW peripherial's
used in my HW design with classical 8051, now I wish to move to DS80C400.
For what AGSI interface exist, when DS80C400 cannot be simulated ???
The program code is:
#include <stdio.h>
#include <ctype.h>
#include <REG400.H>
int proba2(int a);
int proba3(int a);
int proba1(int a)
	proba2(a+4);
	return(a);
int proba2(int a)
	proba3(a-5);
	return(a*a);
int proba3(int a)
	return(a*a);
void main()
	unsigned int data i, j;
    unsigned char data array[10];
    EA = 1;
    // let's print out a little version information...
    //printf("D");
    i = 20;
    j = 100;
    array[5] = 1;
    isprint('u');
	proba1(i);
    while(1)
