I2C random read.
I need to read and write to the location address of unsigned int.Means location beyond the unsigned char i.e 255.
I am pasting the code.It works fine for the writing and reading to the location in the range of unsigned char.
#include <AT89X51.H>
#include <stdio.h>
#include <intrins.h>
#define uchar unsigned char
#define uint unsigned int
#define Byte unsigned char
#define Word unsigned int
#define bool bit
#define true 1
#define false 0
void I2CStart(void);
void I2CStop(void);
bool WaitAck(void);
void SendAck(void);
void SendNotAck(void);
void I2CSendByte(Byte);
Byte I2CReceiveByte(void);
void inoutstat(uchar);
void timetag(uchar);
#define SomeNOP(); _nop_();_nop_();_nop_();_nop_();
void read_mem(uchar );
void write_mem(uchar );
void inoutstat(void);
void timestamp(void);
sbit SDA = P2^0;
sbit SCL = P2^1;
uchar stat,buff[10],wr_buff[10],byte_address[2];
void main(void)
uchar i=0,SOP;
SCON = 0x50; /* SCON: mode 1, 8-bit UART, enable rcvr */
TMOD |= 0x20; /* TMOD: timer 1, mode 2, 8-bit reload */
TH1 = 0xfd; /* TH1: reload value for 1200 baud @ 16MHz */
TR1 = 1; /* TR1: timer 1 run */
TI = 1;
while(1)
SOP=getchar();
if(SOP=='R')
byte_address[0]=getchar();
read_mem(1);
printf("%c",buff[0]);
inoutstat(); // Change the Status (IN -> OUT and OUT -> IN
timestamp(); // Time Stamp the Status Change for attendance
read_mem(7);
for(i=0;i<7;i++)
printf("%c",buff[i]);
SOP=0;
printf("\n");
read_mem(1);
stat=buff[0];
if(stat=='I')
stat='O';
else
stat='I';
wr_buff[0]=stat;
write_mem(1);
uchar id,hr,sec,date,month,yr;
id=byte_address[0];
hr=9;
sec=7;
date=5;
month=11;
yr=4;
wr_buff[0]=id;
wr_buff[1]=hr;
wr_buff[2]=sec;
wr_buff[3]=date;
wr_buff[4]=month;
wr_buff[5]=yr;
wr_buff[6]=stat;
byte_address[0]=1;
read_mem(1);
byte_address[0]=11;
write_mem(7);
void write_mem(uchar count)
int i;
I2CStart();
I2CSendByte(0xA2);
WaitAck();
I2CSendByte(byte_address[0]);
WaitAck();
for(i=0;i<count;i++)
I2CSendByte(wr_buff[i]);
WaitAck();
I2CStop();
void read_mem(uchar count)
uchar i;
I2CStart();
I2CSendByte(0xA2);
WaitAck();
WaitAck();
I2CStart();
I2CSendByte(0xA3);
WaitAck();
for (i=0;i<count;i++)
buff[i]=I2CReceiveByte();
if (i!=count-1) SendAck();
SendNotAck();
I2CStop();
  • 1) Right over the entry window it states "Place source code source code between pre and /pre."
    2) I do not have the time to look at uncommented code.
  • #include <AT89X51.H>
    #include <stdio.h>
    #define bool bit
    #define true 1
    #define false 0
    void I2CStop(void);
    bool WaitAck(void);
    void SendAck(void);
    sbit SDA = P2^0;
    sbit SCL = P2^1;
    void main(void)
    uchar i=0,SOP;
    TI = 1;
    while(1)
    SOP=getchar();
    if(SOP=='R')
    read_mem(1);
    read_mem(7);
    for(i=0;i<7;i++)
    SOP=0;
    printf("\n");
    read_mem(1);
    stat=buff[0];
    if(stat=='I')
    stat='O';
    else
    stat='I';
    wr_buff[0]=stat;
    write_mem(1);
    id=byte_address[0];
    hr=9;
    sec=7;
    date=5;
    month=11;
    yr=4;
    wr_buff[0]=id;
    wr_buff[1]=hr;
    wr_buff[2]=sec;
    wr_buff[3]=date;
    wr_buff[4]=month;
    wr_buff[5]=yr;
    wr_buff[6]=stat;
    byte_address[0]=1;
    read_mem(1);
    byte_address[0]=11;
    write_mem(7);
    int i;
    I2CStart();
    I2CSendByte(0xA2);
    WaitAck();
    WaitAck();
    WaitAck();
    I2CStop();
    uchar i;
    I2CStart();
    I2CSendByte(0xA2);
    WaitAck();
    WaitAck();
    I2CStart();
    I2CSendByte(0xA3);
    WaitAck();
    SendNotAck();
    I2CStop();
  • Have you not heard of indention. Such a sloppy write does not gain from pre and /pre.
    Anyhow nobody can nhelpm you till you specify which eeprom you use.
  • Hi Erik,
    I am trying my best to explain my problem...
    I will be using AT24C512 and what i want to do is write "1" or "0" at memory location 1 to 5 then after 3 bytes of information starting from 7 location till the memory is full.
    for this i want to know how to write at location beyond 255 (unsigned char) address.
    thankx
    rutu
  • have you considered to read the datasheet
    http://www.atmel.com/dyn/resources/prod_documents/doc1116.pdf
    pages 11 and 12 state it all.
  • Hi Erik,
    Thanks, i did it.Now can write to any location on AT24C512 and do Random Read also.
    Rutu.
  • Rutu,
    Do you have to be told to read a datasheet?
