Hello everyone, I hope someone can help me out. I'm kind of stuck. The problem: I have a program which works fine when using a timer to generate the baudrate for the uart. I want to change this to use the internal baudrate generator. I am using the Atmel AT89C51ED2 and have used the code (after my initial try didn't work) from the Armel website.
EA = 0; PCON = 0x10; CKCON0 = 0x7F; CKCON1= 0X01; SCON = 0x50; // UART IN MODE 1 8-BIT, (REN = 1) BDRCON &= 0xEE; // BRR = 0, SRC = 0 BDRCON |= 0x0E; // TBCK=1, RBCK=1, SPD=1 BRL = 100; // APPROX ???? BDRCON |= 0x11; // BRR = 1 ES = 1; EA = 1;
I've tried several things to find the cause of the problem and am near enough sure that uVision2 (my version) doesn't support the internal baudrate generator. I have downloaded a piece of software from the Atmel site (even had a uVision project file) and even this didn't work. I am currently working with : IDE-Version: µVision2 V2.31 Copyright (c) Keil Elektronik GmbH / Keil Software, Inc. 1995 - 2002 C Compiler: C51.exe V7.01 Assembler: A51.exe V7.01 Linker/Locator: BL51.exe V5.01 Librarian: LIB51.exe V4.24 Hex Converter: OH51.exe V2.6 Simulation DLL: S8051.DLL V2.31 Dialog DLL: DP51.DLL V2.31 Does the new version of uVision support the internal BRG. The test software can be downloaded from; http://www.atmel.com/dyn/products/tools_card.asp?tool_id=3420 It might just be time to upgrade. Thanks in advance Regards John Garrelts
Your are using a brand-new device with software that is two years old. C51 Version 7.06 adds simulation support for this device. So it seems that it is time for an upgrade.
