Hi, I've split my project into files. I've defined some global variables in one of the header files as follows: unsigned char ToneDisp[16] = {'D','1','2','3','4','5','6','7','8','9','0',0x2A,0x23,'A','B','C'}; struct channel xdata Ch[16]; unsigned char CHANNELTYPE[16] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}; These variables are used in other files too. Compiling the files individually everything goes fine while building the project results in: *** ERROR L104: MULTIPLE PUBLIC DEFINITIONS How can I avoid this? Shouldn't I 've defined the global variable that way?? Thanks for your attention in advance A.E.
I've defined some global variables in one of the header files as follows: Say no more --- that's exactly your problem already. You should not, repeat: not ever define variables in a header file. Instead, you're supposed to define them in one C source file of your choosing, and declare them in the header file that goes with that source file. This distinction is a basic, generic C issue which has nothing particular to do with C51. It should have been explained to you by your C teacher/tutorial/textbook. If it wasn't, and you're not jumping ahead of the course, I strongly recommend you dump your current source of information and get a better one. The C FAQ, or a second edition copy of Kernighan&Ritchie, or a current edition of Harbison&Steele all should do the trick.
You should not, repeat: not ever define variables in a header file. I always define variables in a header file. I do like this
#ifdef VARACT #define QQQ else #define qqq extern #endif ... #define U8 QQQ unsigned char
no 'mistakes, of a variable defined as twi different things can occur Perhaps, but lots of "didn't correctly #define, lots of multiple definition" mistakes can occur -- as is the original poster's problem. The preprocessor is ugly enough that it's not worth introducing merely to avoid two different definitions. Also, your interface should not change so often that it's really a problem. Even if you need to make a global variable part of the interface to a module, once you choose to do so, that decision is fixed. You shouldn't be updating the definition all the time, any more than you would gratuitiously rename a function constantly.
Also, your interface should not change so often that it's really a problem. Even if you need to make a global variable part of the interface to a module, once you choose to do so, that decision is fixed. You shouldn't be updating the definition all the time, any more than you would gratuitiously rename a function constantly. When making several 'somewhat similar' projects you do everything stated above that you "do not do" after each 'steal' from the previous project. I would, somewhat, agree with Drew if everything you made was started from scratch, but how often do you do that? Erik
I always define variables in a header file. Not really you don't. You just put another layer of cloaking around the fact, using the preprocessor, but at the heart of it, your technique still does what I said has to be done: declare in the header file (i.e. in all "ordinary" uses, in your case), and define in a .c file (the one where you #define VARACT). Actually, as given, that technique has several drawbacks: 1) it only works for uninitialized definitions. You'ld need additional hacks to hide the initializers from client modules. 2) I rather strongly object to #define'ing a type name. The language has the concept of a typedef for a reason. 3) I would object even stronger to mingling the linkage ("extern" or not) into the type name. For one thing, it makes your 'U8' definition unusable for local variables.
3) I would object even stronger to mingling the linkage ("extern" or not) into the type name. For one thing, it makes your 'U8' definition unusable for local variables. I tried to keep it simple, but here we go #define U8 unsigned char // for internal use define UC qqq U8 // for global variable Hans-Bernhard, You have your ideas like I rather strongly object to #define'ing a type name. The language has the concept of a typedef for a reason I honestly don't give a hoot what you do in your place as long as it works for you, In my place I do what works for me. There is no reason, whatsoever, to do something in a given way because K&R makes it possible or suggest it as 'proper'. If one way fit you, use it whatever else K&R may have come up with. My whole 'system' is based on avoiding pitfalls and if the 'improper' use of headers for variables definition saves me ONE mistake I do not give one dime for the properness of it. Erik We can continue this discussion with what is correct While(1){} or for(;;){} but let us not, you have your opinion and is welcome to it, I have mine.
