Hello everyone! I can't make program to work! As I understand the only way for comfortable loading program to TINI is using TINI Loader in bank0. So I decide to load my program to Bank1. But I can't do that directly: when I use Javakit option '-flash 1' and then "load Hex file As TBIN", MessageBox appears and tells that I'm trying to write to Bank0! Why???? I'm new at Keil C. I read "Application Note 606 Configuring Keil PK51 Tools to Support 24-Bit Contiguous Addressing Mode Application Note 606 Configuring Keil PK51 Tools to Support". (http://pdfserv.maxim-c.com/en/an/app606.pdf) I make the same project settings as in that AppNote, use start390.a51,init.a51 with some changes as said in Note, but programm doesn't work. My program is very simple: void main(void) { for(;;){ P5 &= 0xFE; P5 |= 0x01; } } 1.Can you help me with start390.a51 and init.a51 files? 2!!!!.What project settings should I set especially memory settings, because I want to write to the Bank 1? 3.And what is the relation between Bank number and start390 and project settings? Regards, Vasiliy Sergeev
