Note; This topic was sent before but I didn't specify a tool set, so I sent it again We made a small project with AT89C51. It is a simple LED show which can be adjusted by external inputs. We used Keil C. the file compiled with no errors and no warnings. The simulator ( Vault information services simulator) worked perfect. However, when we downloaded the file on the chip, the downloading software produced a strange error: "ERROR on line 259" So, what could be the problem? Is it something common?.( Note: the chip is not defective). here is the C source
/* This code is for the "LED SHOW" project.The idea is to generate the required squence by only changing the value of a 32 bit variable which is px in this code. px is an unsigned long int variable. The function led_out reads a 32 bit variable which is pn then splits it into a four 8 bit variables then sends these variables to the four output ports of 8051 microcontroller. The function unit_delay reads one 8 bit variables "d" which is the number of basic delay units. and resultes in delay = basic_delay_unit * d. in this code basic_delay_unit =.05 sec The function show_generator it's function is to generate the show.you can choose the number of leds used in the show by the variable "no_of_leds". and you can control the speed by the variable "delay".and you can choose if the show is inversion or not -means no_of_leds is on and the rest is off or the inversion- . In this code you can choose the required show and it's speed by the input port P3. by using the following truth tables: P3_2 P3_1 P3_0 0 0 0 MIX 0 0 1 One Led 0 1 0 Two Leds 0 1 1 Three Leds 1 0 0 Four Leds in mix show no other controls needed P3_3 0 Normal Show 1 Inversion Show P3_4 0 Normal Show 1 Show and its Inversion & P3_3 is ignored P3_6 P3_5 Delay 0 0 50 mS 0 1 100mS 1 0 150mS 1 1 200mS P3_7 0 Stop 1 Resume any other cases out of truth table will be igonred */ #include <AT89X51.H> //time base is a 16 bit no. the lowest 8 bits are time_base_l //and the highest 8 bits are time_base)_h. //the time base is the inintial value of timer0 to counts from the time base //to 0xFFFF which generates .05 sec period #define time_base_l 0xB0;//lower time base #define time_base_h 0x3C;//higher time base unsigned char time_delay;//no. of basic_delay units used unit_delay() & time0() only //Functions defination void unit_delay(unsigned char d); void led_out(unsigned long int pn); void show_generator(unsigned char no_of_leds,unsigned char delay,bit inversion_enable); void main(void) { unsigned char show_mode,show_speed,count,i; bit inversion,mode_and_inversion; //adjusting the control registers IP=IP|0x02; //set timer interrupt to have highest priority TMOD=TMOD|0x01; //set timer0 into mode 1 IE=130;//enable interrupts inversion=0; while(1){ show_mode=P3 & 0x07; show_speed=((P3 & 0x60)>>5)+1; if(mode_and_inversion) inversion=~inversion; else inversion=P3_3; mode_and_inversion=P3_4; if(show_mode<=4 && show_mode!=0) show_generator(show_mode,show_speed,inversion); while(show_mode==0){ inversion=0; for(count=1;count<=4;count++){ for(i=1;i<=4;i++){ show_generator(i,count,inversion); show_generator(i,count,~inversion); } } } } } void led_out(unsigned long int pn) { unsigned char i[3],c; /*i[n] is an array of four 8 bit elements that the 32 bit variable pn will split into.such that the LS 8 bits of pn will be stored in i[0] and the next 8 bits will be stored in i[1] and so on. and c is a counter vairable used in for loop. */ for(c=0;c<3;c++){ i[c]=(pn >> (c
"the downloading software produced a strange error: 'ERROR on line 259'" If it really was the downloading software that produced this error (ie, not the compiler or linker), then the line number will refer to the file that you are attempting to download - presumably an Intel Hex file? Does the error message contain any further details? Does the documentation for this downloading software give any further details? What downloading software are you using?
Continued at http://www.keil.com/forum/docs/thread4390.asp#msg18818
