Dear experts, I'm in trouble now. my Keil EPM900 has gone hail-wire I guess. The message that I get whenever I try to put it into debug mode, says ' EPM900 boot loader is not running'. Tried to do as per the warning message said to hard discon and reconnect using INT clock or EXT clock, but still it doesn't work anymore. Can anyone assist in telling me do I refresh the bootloader of the EPM900?? or any suggestion to help it to run again?? appreciate some good advices!! troubled, JM
Please check the following: - disconnect the EPM900 from USB - select the internal RC as clock source:
Options->Debug->Use EPM900 -> Settings -> Oscillator -> Internal RC Oscillator
Which is the bondout chip? I am getting the message "Bootloader ID: Get ID failed!" in the EPM900 debug options. Where can I get a replacement from?
The bondout chip is the big device on the EPM900 board that is in a socket. Where are you located? You need to contact the distributor that has supplied the EPM900. Reinhard
