My Interrupt_1 C code
void EXTERNAL_INT_1 (void) interrupt 2 using 1 { TEST(); } TEST() { if(A=B){ if( C.K[0]==D[0]&&C.K[1]==D[1]&& C.K[2]==D[2]&&C.K[3]==D[3]&& C.K[4]==D[4]&&C.K[5]==D[5]) { if( C.L[0]==E[0]&&C.L[1]==E[1]&& C.L[2]==E[2]&&C.L[3]==E[3]&& C.L[4]==E[4]&&C.L[5]==E[5]) {success==1;} } } }
The using only applies to the function where it appears. Use the #pragma registerbank n to tell the compiler that when directly addressing a register, it should assume that the currently selected register bank is n.
Classic 'C' error:
if(A=B){
Hi, It's my mistake. I want to describe the problem keypoint and don't care about the syntax error. I try to put the #pragma rb(1) into Test(){} but it doesn't work. Any suggestion ? Thanks.
Refer to http://www.keil.com/support/man/docs/c51/c51_registerbank.htm. Jon
I try to put the #pragma rb(1) into Test(){} You need to be careful where you put the pragma - it must go before the function definition - not in it.
